Discuss
comb stuck in lint trap chute
 in
Dryer Repair
I have a front load Samsung Dryer, was trying to use hair comb to clean lint from lint trap and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » comb stuck in lint trap chute
  #1 (permalink)
Old 09-09-2012, 11:50 AM
Junior Member
danyelle is on a distinguished road
Angry comb stuck in lint trap chute
Brand: Samsung   Age: 1 - 5 years
I have a front load Samsung Dryer, was trying to use hair comb to clean lint from lint trap and comb fell into lint chute ...Cannot each it, how do i get to it???
Thanks, Danyelle
  #2 (permalink)
Old 09-10-2012, 03:57 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Since it is a Samsung info on the unit may be difficult to find on the net.
If you can see the comb then perhaps the old gum on a stick will work.
I would only do this if it is a fairly easy grab as you do not want to loose the gum in the unit.
You could also buy a pick up tool similar to the following but you do not need a fancy one.
Mayhew Tool LED Lighted Pick Up Claw | Pick-Up Tools and Mirrors
Depending if you can see the comb and you can slip a string around it, you may be able to jiggery pokery a pick up tool. get a piece of tubing or pipe.
Thread a string through it so there is a loop at one end. Slip the loop over the comb then pull the string ends to tighten up the loop and with luck get the comb out.
If none of the above work then you will have to take the unit apart but without info I cannot say what that will entail.
Or perhaps someone else has better suggestions.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lint deep in the lint trap BJohnston Dryer Repair 0 01-05-2012 09:05 AM
Lint trap Nallfamily Dryer Repair 0 12-24-2010 07:00 AM
Lincoln Log in Lint Trap hgrib Dryer Repair 3 07-08-2010 10:41 AM
Ice Chute Trap Door franceswagner Refrigerator & Freezer Repair 1 03-05-2009 03:19 PM
something in lint trap lesliekim Dryer Repair 3 05-08-2008 06:21 PM
