Discuss
Replacement Drive Pulley for Maytag Performa
 in
Dryer Repair
I have a Maytag Performa PDET910AYW and the motor's drive pulley needs to be replaced. It appears they have made
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Replacement Drive Pulley for Maytag Performa
  #1 (permalink)
Old 09-08-2012, 10:01 PM
Junior Member
dsuper11 is on a distinguished road
Default Replacement Drive Pulley for Maytag Performa
Brand: Maytag   Age: 5 - 10 years
I have a Maytag Performa PDET910AYW and the motor's drive pulley needs to be replaced. It appears they have made it to where you must buy the entire mortor to get the pulley. Is there anything that can make a subtitute for this pulley. The pulley's original part number has 754305 stamped on it. It appears the Idler Pulley assembly gave out and the motor kept trying to spin and eventually removed the threads for the drive pulley and is now dead in the water. The part used to be sold seperatley, but thru some new sales strategy it now only comes with the motor. Please help me with this issue.
Ads By Google
  #2 (permalink)
Old 09-10-2012, 04:17 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
I cannot find the pulley anywhere , with luck someone else will.
Also I would not order a motor till you get the blower wheel off of it as often it has to be destroyed (seizes to the shaft)
If the pulley fits tightly onto the shaft you could try drilling through it and the shaft and installing a pin.
OR
Install a lock screw in the pulley. But unless you have the proper tools (tap, etc.), this could be a no go.
I do not think this was just a sales strategy. More likely it was to fix the same problem as you are having.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Performa washer snubber replacement richappy Washer Repair 21 05-15-2012 05:42 PM
Drive Pulley TOM VITAZ Washer Repair 1 10-21-2011 06:30 PM
Maytag Atlantis Drive Belt Replacement ??? oaktree Washer Repair 1 09-02-2011 07:03 AM
change drive belt and drive pulley clacker48 Washer Repair 2 03-08-2010 11:13 AM
drive pulley acuevas Washer Repair 3 06-03-2009 03:06 PM
