| » dryer works but will not 'heat-up' to dry the clothes |
Model Number: WGD5600XW0 Brand: Whirlpool Age: 1 - 5 years
Dryer runs fine, however will not dry the clothes. Will not 'heat up'. Has new valve assembly, new coils and new igniter. When I start the dryer, it seems to run fine. When it comes time for the igniter to come 'on' and start glowing, all that happens is a single, fairly loud 'click' that seems to come from the coil area. The igniter does not heat up. Dryer continues to run until end of timed cycle with no flame. Please help. Getting too cold to dry clothes on the clothes-line.
Make sure that the exhaust line is not clogged and the air flow is not restricted.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Just checked the air flow, did have a 'build up' of lint. Replaced the igniter and everything working fine now. Think it was the igniter. Igniter had a white spot the way you described in a different post. Helped locate the problem. Thank You Last edited by man599 : 09-12-2012 at 02:14 PM. |
You are welcome. I'm glad you were able to fix it.
__________________
| Display Modes | |
| Dryer will not heat clothes | cathoward | Dryer Repair | 10 | 12-16-2011 08:40 PM |
| Dryer won't heat up to dry clothes | tdeai | Dryer Repair | 1 | 07-22-2011 05:18 AM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer works until you put clothes in it | mccdeuce | Dryer Repair | 4 | 04-28-2009 05:39 AM |
| Gas clothes dryer no heat | kwclark | Dryer Repair | 0 | 01-23-2009 12:23 PM |
