| » Kenmore Gas Dryer No heat |
Model Number: 110722121101 Brand: Kenmore Age: 5 - 10 years
My dryer will turn on, but it will not get hot. I think it is the ignition or the fuse, but I am not sure.
You must check all the thermostats and the fuse in the back of the dryer to see if they are good then if they are not replace it if they are then you will have to test the igniter by removing the plug in the front of the dryer to see if the igniter glows when it is turned on or just test it for continuty if that not your test the flame sensor for continuty if it passes then you will have to replace the dryer coils
| Display Modes | |
| Kenmore gas dryer-no heat | aer143 | Dryer Repair | 0 | 01-24-2011 05:41 AM |
| Kenmore Dryer - Timer not moving with No heat and dryer does not shut off | poslow | Dryer Repair | 2 | 11-21-2010 10:10 PM |
| Kenmore dryer heats on low heat but not on high heat | Mrhollywood334 | Dryer Repair | 0 | 09-11-2010 09:33 PM |
| No Heat From Kenmore Gas Dryer | grazzin | Dryer Repair | 2 | 09-16-2009 03:40 PM |
| Kenmore dryer will not heat | lpennock | Dryer Repair | 2 | 05-11-2009 06:19 AM |
