Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Dryer won't heat up (http://forum.appliancepartspros.com/dryer-repair/49882-dryer-wont-heat-up.html)
Jeff Thames 09-22-2009 01:43 PM
Dryer won't heat up
My whirlpool dryer wont heat up.
denman 09-23-2009 03:10 AM
Replacement parts for WHIRLPOOL LER5634AW0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/w...%203399125.pdf
I am assumning that the drum rotates OK
First thing to check is the power. Flip the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker and the heater requires both sides to get 240 volts.
Better yet check it with a meter.
Next would be the heater itself, then the thermal fuse (Item 7 in Section 3) then the thermostats.
