Discuss
Dryer motor burned, but.......
 in
Dryer Repair
My dryer stopped running so I checked the thermal cutoff by bypassing it. Motor started up so I thought it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer motor burned, but.......
  #1 (permalink)
Old 09-02-2012, 12:24 PM
Junior Member
pgko is on a distinguished road
Default Dryer motor burned, but.......
Model Number: 110.68732700   Brand: Kenmore   Age: 1 - 5 years
My dryer stopped running so I checked the thermal cutoff by bypassing it. Motor started up so I thought it would be okay to let my wife finish her load. Bad idea! The motor wouldn't start after that. To test the motor to confirm it was bad, I made a 110volt test cord and plugged it in. The motor ran, but cuts out with a burning smell, so I'm willing to accept that its bad and replace it. However, something else is bothering me and I don't want to find other problems after I do that. Why does the motor run when running 110volt directly to it, but not when its plugged in via the 220volt power cord? I don't even get a voltage reading through the 220volt cord. Door switch, start switch and timer motor all tested good with a multi-meter.
Ads By Google
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 09-05-2012, 08:26 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Sorry but I do not understand the above. I think I am reading it wrong.
Do you mean that there is no 220 at the terminal strip in the unit?
OR
That there is no 120 volts at or across the motor?
Did you check the thermal fuse on the blower? It will kill power to the motor.
__________________
  #3 (permalink)
Old 09-05-2012, 08:53 AM
Junior Member
Default misc.
What I mean is that if I remove the 110volt test cord and apply my volt meter clips to the same wires it was attached to, then plug in the 220 volt cord and hit the start switch, I get nothing on the volt meter.
Thermal fuse is completely bypassed (wires spliced together) although it tested fine. I get a click now and then from the timer motor, but that tested fine too.
  #4 (permalink)
Old 09-05-2012, 09:15 AM
Senior Expert
APP Volunteer
Default
I cannot find a wiring diagram for this unit so have to do some guessing.
Does the drum light work?
Have you checked the power at the terminal strip? In this case the L1(black) to Neutral (white) is what matters.
Perhaps try unplugging the unit and measuring L1 to Neutral with the timer at off. Then with the timer mid scale of a heating mode. I am not sure what the ohms reading should be as your timer motor and thermostat heater may be in circuit. Then push the start button and it should drop to a couple ohms as you are switching in the motor windings.
If not then there is an open somewhere.
With luck you have the wiring diagram and then can attach one meter lead to L1 and work your way back through the motor circuit till you find the open.
The circuit is often L1 , BK/BU timer contacts , thermal fuse , motor windings , start switch , door switch , Neutral.
__________________
  #5 (permalink)
Old 09-21-2012, 05:02 AM
Junior Member
Default motor problems
Okay, I've finally replaced the motor. Still have part of the same problem. If I hook up a 110 test cord directly to it, it runs fine. However, when plugged into the 240 wall outlet, nothing. I've checked every single component and they all test good. I've even tried bypassing the fuse and thermal switch just in case I was reading them wrong.
One thing, I cannot get a voltage reading on the red and white wire coming from the start switch to the motor because I cannot press the button and take a reading at the same time. Therefore, I bypassed the switch by touching the two wires together and I get 119 volts right next to the motor.
Another thing, when I read the voltage from the thick red wires on the heating coil, by going from the leads to a ground, I get 120 volts, not 240. Should that be the case?
I'm lost. Please help!!!!!
  #6 (permalink)
Old 09-22-2012, 03:12 AM
Senior Expert
APP Volunteer
Default
Without a wiring diagram I cannot be of much help.
You have to check the motor start circuit path.
Yes.
On most units there is always 120 volts (L1 side of the line) at the heater when the timer is in a heating mode.
The heater circuit does not use ground (120 volts) so using it as a reference can be confusing as you will not see 240 volts across the heater until the motor is running. The motor's heat centrifugal switch switches in the other side of the line (L2). This then gives 240 volts (L1 to L2) across the heater (red to red).
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Motor burned out? jasondkramer Dryer Repair 2 03-03-2012 06:49 AM
Maytag Washer--burned out motor? or is there anything else to check abm007 Washer Repair 1 12-30-2010 03:18 AM
burned out motor on my Amana Fridge? ladye1955@hotmail.com Refrigerator & Freezer Repair 4 06-06-2009 08:26 PM
motor burned up and new motor smells like burning on trying russ595 Washer Repair 1 02-01-2009 01:42 PM
burned motor control board jnhb Washer Repair 1 07-15-2008 03:18 AM
