Discuss
Whirkpool running hot & vents have been throurghly checked
 in
Dryer Repair
Vents on dryer are clear and vent from dryer to oute was removed and checked and was clear. Dryer temp
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirkpool running hot & vents have been throurghly checked
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-02-2012, 08:46 AM
Junior Member
lr9147 is on a distinguished road
Default Whirkpool running hot & vents have been throurghly checked
Model Number: LER4634DQO   Brand: Whirlpool   Age: 5 - 10 years
Vents on dryer are clear and vent from dryer to oute was removed and checked and was clear. Dryer temp get very hot very quickly. There was never a problem until I tried drying towel twice that were not drying, then discovered belt was broken.
Replaced belt but dryer but dryer to hot to use. Even heats on cool down. Timer moves as usual. Is only problem, motor runs and drum tumbles.
Related Models
Whirlpool LER4634DZ0 DRYERS
Whirlpool LER4634DZ1 ELECTRIC DRYER
Whirlpool LER4634EQ0 ELECTRIC DRYER
Whirlpool LER4634EQ1 DRYERS
Whirlpool LER4634EQ2 ELECTRIC DRYER
Whirlpool LER4634EW0 ELECTRIC DRYER
Whirlpool LER4634EZ0 ELECTRIC DRYER
Whirlpool LER4634EZ1 DRYERS
Whirlpool LER4634EZ2 ELECTRIC DRYER
Whirlpool LER4634JQ0 ELECTRIC DRYER
Whirlpool LER4634JQ1 RESIDENTIAL DRYER
Whirlpool LER4634JQ2 29" ELECTRIC DRYER
Whirlpool LER4634JT0 ELECTRIC DRYER
Whirlpool LER4634JT1 RESIDENTIAL DRYER
Whirlpool LER4634JT2 29" ELECTRIC DRYER
Whirlpool LER4634JZ0 ELECTRIC DRYER
Whirlpool LER4634PQ0 29" ELECTRIC DRYER
Whirlpool LER4634PQ1 29" ELECTRIC DRYER
Whirlpool LER4634PT0 29" ELECTRIC DRYER
Whirlpool LER4634PT1 29" ELECTRIC DRYER
Whirlpool LER5434AW0 Residential Dryer
Whirlpool LER5600HQ0 ELECTRIC DRYER
Whirlpool LER5600HZ0 ELECTRIC DRYER
Whirlpool LER5600JQ0 ELECTRIC DRYER
Whirlpool LER5600JT0 ELECTRIC DRYER
Whirlpool LER5620KQ0 RESIDENTIAL DRYER
Whirlpool LER5620KQ1 ELECTRIC DRYER
Whirlpool LER5620KQ2 29"ELECTRIC DRYER
Whirlpool LER5624BN0 ELECTRIC DRYER
Whirlpool LER5624BN1 ELECTRIC DRYER
Whirlpool LER5624BN2 ELECTRIC DRYER
Whirlpool LER5624BW0 ELECTRIC DRYER
Whirlpool LER5624BW1 ELECTRIC DRYER
Whirlpool LER5624BW2 ELECTRIC DRYER
Whirlpool LER5624DQ0 DRYERS
Whirlpool LER5624DQ1 ELECTRIC DRYER
Whirlpool LER5624DW1 ELECTRIC DRYER
Whirlpool LER5624DZ0 DRYERS
Whirlpool LER5624DZ1 ELECTRIC DRYER
Whirlpool LER5634AN0 ELECTRIC DRYERS
Whirlpool LER5634AQ0 ELECTRIC DRYER
Whirlpool LER5634AQ1 ELECTRIC DRYER
Whirlpool LER5634AQ2 ELECTRIC DRYER
Whirlpool LER5634AW0 ELECTRIC DRYERS
Whirlpool LER5634DQ1 DRYER
Whirlpool LER5634EQ0 ELECTRIC DRYER
Whirlpool LER5634EZ0 ELECTRIC DRYER
Whirlpool LER5634LG0 RESIDENTIAL DRYER
Whirlpool LER5634LQ0 29" ELECTRIC DRYER
Whirlpool LER5634LT0 RESIDENTIAL DRYER
Whirlpool LER5634LW0 RESIDENTIAL DRYER
Whirlpool LER5635LQ0 29"ELECTRIC DRYER
Whirlpool LER5635LQ1 29"ELECTRIC DRYER
Whirlpool LER5636DW0 ELECTRIC DRYER
Whirlpool LER5636DW1 ELECTRIC DRYER
Whirlpool LER5636EQ0 ELECTRIC DRYER
Whirlpool LER5636EQ1 ELECTRIC DRYER
Whirlpool LER5636EQ2 ELECTRIC DRYER
Whirlpool LER5636EQ3 ELECTRIC DRYER
Whirlpool LER5636EZ0 ELECTRIC DRYER
Whirlpool LER5636EZ01 ELECTRIC DRYER
Whirlpool LER5636EZ1 DRYER
Whirlpool LER5636EZ2 ELECTRIC DRYER
Whirlpool LER5636EZ3 ELECTRIC DRYER
Whirlpool LER5636JQ0 ELECTRIC DRYER
Whirlpool LER5636JT0 ELECTRIC DRYER
Whirlpool LER5636KQ0 RESIDENTIAL DRYER
Whirlpool LER5636KQ1 RESIDENTIAL DRYER
Whirlpool LER5636KT0 RESIDENTIAL DRYER
Whirlpool LER5636KT1 RESIDENTIAL DRYER
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"ELECTRIC DRYER
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"ELECTRIC DRYER
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"ELECTRIC DRYER
Whirlpool LER5636PQ1 29"ELECTRIC DRYER
Whirlpool LER5636PT0 29"ELECTRIC DRYER
Whirlpool LER5636PT1 29"ELECTRIC DRYER
Whirlpool LER5638AN1 ELECTRIC DRYER
Whirlpool LER5638AN2 ELECTRIC DRYER
Whirlpool LER5638AN3 ELECTRIC DRYER
Whirlpool LER5638AW0 Residential Dryer
Whirlpool LER5638AW1 ELECTRIC DRYER
Whirlpool LER5638AW2 ELECTRIC DRYER
Whirlpool LER5638AW3 ELECTRIC DRYER
Whirlpool LER5644AN1
Whirlpool LER5644AN2 ELECTRIC DRYER
Whirlpool LER5644AW0 Residential Dryer
Whirlpool LER5644AW1
Whirlpool LER5644AW2 ELECTRIC DRYER
Whirlpool LER5644EQ0 ELECTRIC DRYER
Whirlpool LER5644EQ1 ELECTRIC DRYER
Whirlpool LER5644EQ2 ELECTRIC DRYER
Whirlpool LER5644EZ0 ELECTRIC DRYER
Whirlpool LER5644EZ1 ELECTRIC DRYER
Whirlpool LER5644EZ2 ELECTRIC DRYER
Whirlpool LER5644JQ0 DRYER
Whirlpool LER5644JQ1 DRYER
Whirlpool LER5644JQ2 RESIDENTIAL DRYER
Whirlpool LER5644JQ3 29"ELECTRIC DRYER
Whirlpool LER5644JT0 DRYER
Whirlpool LER5644JT1 DRYER
Whirlpool LER5644JT2 RESIDENTIAL DRYER
Whirlpool LER5644JT3 29"ELECTRIC DRYER
Whirlpool LER5644PQ0 29"ELECTRIC DRYER
Whirlpool LER5644PQ1 29"ELECTRIC DRYER
Whirlpool LER5700KQ0 RESIDENTIAL DRYER
Whirlpool LER5700KQ1 RESIDENTIAL DRYER
Whirlpool LER5700KT0 RESIDENTIAL DRYER
Whirlpool LER5700KT1 RESIDENTIAL DRYER
Whirlpool LER5848EQ0 ELECTRIC DRYER
Whirlpool LER5848EQ1 ELECTRIC DRYER
Whirlpool LER5848EQ2 ELECTRIC DRYER
Whirlpool LER5848EQ3 DRYERS
Whirlpool LER5848EQ4 DRYERS
Whirlpool LER5848EQ5 ELECTRIC DRYER
Whirlpool LER6611LQ0 RESIDENTIAL DRYER
Whirlpool LER6611LQ1 29"ELECTRIC DRYER
  #2 (permalink)
Old 09-05-2012, 08:33 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for Whirlpool LER4634DQ0 DRYERS | AppliancePartsPros.com
Could be a grounded element.
Unplug the unit and the wires at the heating element.
Measure across the element, should be 8 to 12 ohms.
Then measure from each side of the element to the frame.
Both should be infinite ohms.
If not the element has sagged or broken and is touching the case.
This can cause it to run on high all the time.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
  #3 (permalink)
Old 09-07-2012, 06:48 PM
Junior Member
Default
I really appreciate your response once again about my dryer overheating problems. I am not famiiar at all with doing the posts so I had to start over & am glad you responded. I bought me a digital multimeter for under $20 as you suggested. However I didn't read your post again before going online to see how to use the meter so I tested the heater element for continuity after it was already removed from the dryer and got a reading of 006. Im not sure what you were suggesting, I undestand the frame should be the metal part around the coils but after that I am lost. I have more experience washing & drying clothes than repair. However I have learned many things taking the diy route and love to save money while learning. I have someone I used to work with you can help if needed, but lives too far to ask to come & help until I have figured where the problem is. I tested the hi limit thermostat and if I did that correctly the reading is 0000. I used the places right below the thermostat where wires were connected to test. Is there anything else I can try now or if you need to explain more about the heat element testing I will try again to follow your directions. Thank you
  #4 (permalink)
Old 09-08-2012, 03:44 AM
Senior Expert
APP Volunteer
Default
see the attachment for your wiring diagram.
If you trace out the circuit ( colored pencils can help you do this) for the heating element you will see it runs off of 240 volts (L1 to L2). If your unit uses a 3 wire line cord then Neutral and the earth ground (machine frame are connected together). Neutral is not part of the heater circuit.
What can happen is that the heater coil can sag or break and touch the case/frame. Depending how it does this then part of the coil is connected from L1 or L2 to Neutral and current can flow but the thermostats cannot regulate it. So the heating coil should always measure infinite ohms (open) when checked to Neutral/frame.
FYI: Your house actually has two 120 volt supplies (L1 and L2) that use a common Neutral. The supplies are 180 degrees out of phase. So when one is at 120 volts positive, the other is at 120 volts negative (when referenced/measured to Neutral) so if you measure L1 to L2 you get 240 volts. This is then what is used to power the heating coil.
The way you measured it sounds OK to me.
It is what you would expect.
I doubt this is your problem as the hi-limit is a safety device so if everything is OK it never opens.
I hope the above is helpful and I did not confuse you.
__________________
  #5 (permalink)
Old 09-10-2012, 01:29 PM
Junior Member
Default
Thanks so much for your help. After trying the digital meter again and figuring out that the wiring was as it should be, i decided to check my vents one more time since they were usually the overheating cause. I had already taking the outside vent out and ran a brush through it and one detached I could see nothing in there. So I tried the vent filter in the dryer again by running a brush in an out and still nothing. As a last resort I unscrewed the vent and took it out and then seeing nothing still, I unscrewed the cover that went over the fan, motor, etc. Finally down in there was a wad of lint that the brush couldn't reach and couldn't be blown out out. After checking my dryer is running as it should and temp is back to normal. Thanks for helping a girl out, I do appreciate your help and thanks for suggesting the digital multimeter, you were right I do think it was work the less than $20 it cost to rule out the electrical parts that were not the problem. Problem resolved. I am so grearful for this site all of you that are helping people.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
refrigerator whirpool vents randc Refrigerator & Freezer Repair 0 11-22-2011 06:47 AM
Vents icing up Dbear13 Refrigerator & Freezer Repair 10 12-03-2010 10:42 AM
Fridge not cooling down checked the fun not running theopinto Refrigerator & Freezer Repair 1 12-22-2009 07:55 AM
Fridge not cooling down checked the fun not running theopinto Refrigerator & Freezer Repair 1 12-22-2009 07:54 AM
Whirkpool gas dryer not heating blackerhome@cox.net Dryer Repair 0 03-24-2009 01:36 PM
