| » No Heat, No Timer, New Cycling Thermostat, New Fuse, Good Continuity |
Model Number: lgb6200pq1 Brand: Whirlpool Age: 5 - 10 years
My dryer won't heat up and the timer won't work. I replaced the timer and that did nothing. I then proceeded to replace the Cycling Thermostat and Fuse after a continuity check showed that the fuse had blown. The dryer heated up for about 5 minutes and the timer worked as well. Everything went fine until after that 5 minutes everything went back to no heat and no timer. I'm guessing the fuse blew again. When I was doing continuity checks initially the coils checked out fine. The 1220 ohm fuse came out to about 1320. It's about +100 what it should have been. I didn't see this as being a problem since you could hear the solonoid turning on and off. The igniter is glowing and the continuity checked out about +100 on the flame sensor as well. Please let me know if I should proceed with replacing the coils regardless of the continuity test. I'm tired of buying parts and not getting the problem fixed.
Thanks in advance! Ads By Google Related Models |
| Display Modes | |
| continuity on cycling thermastat | bhearty | Dryer Repair | 0 | 11-27-2011 04:03 PM |
| Only heats for a short time; already changed thermal fuse and cycling thermostat | srelliott | Dryer Repair | 0 | 10-19-2011 07:49 PM |
| Replace high limit thermostat a or cycling thermostat along with the thermal fuse? | BrassMonkey | Dryer Repair | 1 | 11-15-2010 06:23 PM |
| No heat. Thermostat reads 3.5 ohms. Good or bad? | gatorsfan | Dryer Repair | 6 | 11-04-2008 02:37 PM |
| Oven won't heat - good continuity | jhd | Oven Repair (including Ranges and Cooktops) | 0 | 10-12-2008 07:27 PM |
