| » Timer |
Model Number: MDG6400AWW Brand: Maytag Age: 1 - 5 years
Timer Sticks In Normal Cycle, Runs Forever, Had Service Out, Needs
New Timer, Part Ap4043083, Ordered It, Need Install Instructions, Looks Easy But Do You Have Any Help? Ads By Google Related Models |
Do not rush with the timer.
One of the most common cause for such problem is an obstructed air flow. The first thing I would do is clean the vent all the way from the dryer back panel through the vent outlet. Make sure the outlet flopper is opening properly. Take the dryer apart. Check the blower wheel and clean all air ducts inside. If there is nothing wrong then replace the high limit thermostat (#17 on the diagram) and the cycling thermostat (#8 on the diagram). Here is the Service manual. - The high limit thermostat Part number: AP4036956 - The cycling thermostat Part number: AP4037199 Here are the breakdown diagrams and Replacement parts for MAYTAG MDG6400AWW | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Burner does not come on all the time either, runs for about 10-15 sec and skips times that ignitor comes on some times, several times ignitor lights
but flame does not happen. Ran it on timed cycle which appears to advance, normal cycle does not. I did replace high temp limit above burner #17 on drawings. Again have maytag. Hoping its not the coils of the burner. Timer still does not advance on normal dry cycle. Air is flowing well outside at vent. had a service guy out but he really did nothing for $40. Suppose I'll call another one. |
Sorry for the delay.
Quote:
- The coil kit Part number: AP3094251 Gene.
__________________
| Display Modes | |
| timer | wildcat9696 | Dryer Repair | 0 | 01-24-2010 12:05 PM |
| Kenmore Dryer Timer not advancing in Auto Dry or Timer Mode but it does heat and dry | dspeidel | Dryer Repair | 6 | 08-25-2009 02:23 PM |
| GE Top Loader--Problem with Timer Knob or Timer | crmothorpe | Washer Repair | 3 | 04-27-2009 06:08 AM |
| timer does not run | scotthelland | Dryer Repair | 0 | 02-15-2008 02:01 PM |
| timer gone? | aefabf | Dryer Repair | 1 | 02-14-2008 02:24 AM |
