Discuss
Maytag LSG7804AAE Dryer - Won't Heat Up
 in
Dryer Repair
Hi. My retired father has a Maytag LSG7804AAE dryer, which is a stacked unit above the washer. The dryer spins
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag LSG7804AAE Dryer - Won't Heat Up
  #1 (permalink)
Old 01-29-2008, 05:07 PM
HockeyDave HockeyDave is offline
Junior Member
HockeyDave is on a distinguished road
Exclamation Maytag LSG7804AAE Dryer - Won't Heat Up
Model Number: LSG7804AAE   Brand: Maytag   Age: 5 - 10 years
Hi. My retired father has a Maytag LSG7804AAE dryer, which is a stacked unit above the washer. The dryer spins but there is no heat. After looking at Model LSG7804AAE and Model LSG7804AAE we purchased and installed a flame sensor and multi-temp thermostat. We also cleaned the vents, screen intake area and made sure all other airflow is clear. However we still have the same issue, no heat in the dryer.
Do you think that this could be the gas valve, gas orifice, dryer igniter or something else?
Thank you Gene and the other AppliancePartsPro team for the great work that you all do. You all are the best. Cheers. :-)
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-29-2008, 08:48 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Dave,
Remove the front access panel, unplug the igniter and check it for continuity.
Replace the igniter if the circuit is open.
If there is nothing wrong, check for continuity the hi limit thermostat (#17 on the gas valve break down diagram).
Replace it if the circuit is open.
- The part number for the igniter is AP3109449
- The part number for the hi limit thermostat is AP275754
Post your findings, please.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-14-2008, 11:11 AM
frankkie frankkie is offline
Junior Member
frankkie is on a distinguished road
Arrow
have similar problem. Maytag gas dryer LDG482, ignitor lights up gas valve does not open...dryer just runs....bad gas valve or control problem?
  #4 (permalink)
Old 02-14-2008, 12:02 PM
Junior Member
Default Worked like a charm...
Gene - your recommendation was right on. I replaced both parts and everything is working like a charm. Many thanks.
  #5 (permalink)
Old 02-14-2008, 01:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi frankkie,
Did the igniter stay "on" all the time or it was cycling?
Make sure the gas shut off valve behind the dryer is open.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help with Maytag Dryer-won't heat up momto3 Dryer Repair 0 01-23-2008 09:54 AM
Maytag Dryer derwin Dryer Repair 0 11-16-2007 07:07 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
Maytag dryer ARRABITOT Dryer Repair 2 10-20-2007 03:37 AM
maytag gas dryer will not heat after initial burn Agustin Dryer Repair 1 08-28-2007 10:48 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
