Discuss
Kenmore/Maytag Gas Dryer not kicking up
 in
Dryer Repair
Gas dryer was purchased in 2003 and converted from gas to propane. It has been sitting in storage since 2008,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore/Maytag Gas Dryer not kicking up
  #1 (permalink)
Old 08-28-2012, 10:59 PM
Junior Member
mwrluthier is on a distinguished road
Default Kenmore/Maytag Gas Dryer not kicking up
Model Number: 417.93042202   Brand: Kenmore   Age: 5 - 10 years
Gas dryer was purchased in 2003 and converted from gas to propane. It has been sitting in storage since 2008, and now I have landed in a house with gas available. I exchanged the parts that were left by the repairman that converted it to propane, and the gas burner will not kick on. There is a sticker inside the front bottom that states "This dryer has been converted to use LP gas at 11# manifold pressure. The dryer has been reorificed and the pressure regulator has been immo ilized to a full open position with a block open plug." I exchanged the burner tip and the pressure plug with what was in it originally. I've opened the front to check for any loose wire connections. Wondering if some dust got in the gas line so I'm going to dismantle the gas orrifice and blow the flex line out for general good measure. Don't know where to go from there.
Any thoughts on how to get the gas to kick on??? Gas line seems to have plenty of gas in it!!!
Related Models
Kenmore 41715644 OUTDOOR GRILL
Kenmore 41724182300 WASHER
Kenmore 41724182301 WASHER
Kenmore 41727182700 WASHER
Kenmore 41727182701 WASHER
Kenmore 41727182702 WASHER
Kenmore 41727182703 WASHER
Kenmore 41727182704 WASHER
Kenmore 41729022890 FREESTANDING WASHER
Kenmore 41729042990 FRONTLOAD WASHER
Kenmore 41729042991 KENMORE WASHER
Kenmore 41729042992 FRONT LOAD WASHER
Kenmore 41729052990 KENMORE WASHER
Kenmore 41729052991 WASHER
Frigidaire 41739012890 Frg(v0) / Washer
Kenmore 41739012890 STACK WASHER
Kenmore 41739012891 WASHER
Frigidaire 41739012891 WASHER
Frigidaire 41739022890 Frg(v0) / Washer
Kenmore 41739022891 WASHER
Frigidaire 41739022891 Frg/washer
Kenmore 41740032990 WASHER
Kenmore 41740042990 WASHER
Kenmore 41740052990 WASHER
Kenmore 41740142000 WASHER
Kenmore 41740412700 WASHER
Kenmore 41740412701 WASHER
Kenmore 41740412702 SEARS/FRONT LOAD WASHER -0582
Kenmore 41740412703 WASHER
Kenmore 41741042000 WASHER
Kenmore 41741052000 FRONTLOAD WASHER
Kenmore 41741100000 WASHER
Kenmore 41741101000 WASHER
Kenmore 41741102000 WASHER
Kenmore 41741142000 RESIDENTIAL WASHER
Kenmore 41742042100 WASHER
Kenmore 41742052100 WASHER
Kenmore 41742142100 WASHER
Kenmore 41743042200 SEARS/FRONTLOAD WASHER
Kenmore 41743042300 WASHER
Kenmore 41743052200 SEARS/FRONTLOAD WASHER
Kenmore 41743142200 SEARS/FRONTLOAD WASHER
Kenmore 41743142300 WASHER
Kenmore 41744042400 WASHER
Kenmore 41744052400 WASHER
Kenmore 41744052401 WASHER
Kenmore 41744052500 WASHER
Kenmore 41744072300 WASHER
Kenmore 41744082400 WASHER
Kenmore 41744082500 WASHER
Kenmore 41744092500 WASHER
Kenmore 41744102300 WASHER
Kenmore 41744102301 WASHER
Kenmore 41744130000 WASHER
Kenmore 41744131000 WASHER
Kenmore 41744132000 WASHER
Kenmore 41744142400 WASHER
Kenmore 41744152400 WASHER
Kenmore 41744152401 WASHER
Kenmore 41744152500 WASHER
Kenmore 41744252500 WASHER
Kenmore 41744252501 WASHER
Kenmore 41747102700 WASHER
Kenmore 41747102701 WASHER
Kenmore 41748102700 WASHER
Kenmore 41748102701 WASHER
Kenmore 41748106700 WASHER
Kenmore 41748112700 WASHER
Kenmore 41748112701 WASHER
Kenmore 41748116700 WASHER
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Kenmore 41759012890 GAS DRYER
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41759022890 GAS DRYER
Kenmore 41764182300 ELECTRIC DRYER
Kenmore 41769042990 KENMORE DRYER
Kenmore 41769042991 DRYER
Kenmore 41769052990 DRYER
Kenmore 41769052991 ELECTRIC DRYER
Kenmore 41774182300 GAS DRYER
Kenmore 41774182301 GAS DRYER
Kenmore 41779042990 DRYER
Kenmore 41779042991 DRYER
Kenmore 41779052990 DRYER
Kenmore 41779052991 DRYER
Kenmore 41780032990 DRYER
Kenmore 41780042990 DRYER
Kenmore 41780042991 DRYER
Kenmore 41780052990 DRYER
Kenmore 41780052991 DRYER
Kenmore 41780142000 DRYER
Kenmore 41780412700 DRYER
Kenmore 41781042000 DRYER
Kenmore 41781042001 DRYER
Kenmore 41781052000 ELECTRIC DRYER
Kenmore 41781052001 DRYER
Kenmore 41781100000 DRYER
Kenmore 41781101000 DRYER
Kenmore 41781102000 DRYER
Kenmore 41781142000 DRYER
Kenmore 41781142001 DRYER
Kenmore 41782042100 DRYER
Kenmore 41782042101 DRYER
Kenmore 41782042102 SEARS/DRYER
Kenmore 41782052100 DRYER
Kenmore 41782052101 DRYER
Kenmore 41782052102 DRYER
Kenmore 41782052103 SEARS/ELECTRIC DRYER
Kenmore 41782142100 DRYER
Kenmore 41782142101 DRYER
Kenmore 41782142102 SEARS/ELECTRIC DRYER
Kenmore 41783042200 SEARS/DRYER
Kenmore 41783042201 SEARS/ELECTRIC DRYER
Kenmore 41783042300 DRYER
Kenmore 41783052200 SEARS/DRYER
Kenmore 41783052201 SEARS/DRYER
Kenmore 41783142200 SEARS/DRYER
Kenmore 41783142201 SEARS/ELECTRIC DRYER
  #2 (permalink)
Old 08-29-2012, 06:54 AM
Junior Member
Default
Tried pulling off the front face to inspect and try to determine if it was trying to light up. Turned the dryer on with the door assembly removed, there was a flash in the location of the gas burner like the unit had tried to light, and it blew the GFI plug the dryer was plugged in to. Perhaps a stupid newbie mistake???
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
TCO keeps kicking out Billi Dryer Repair 2 05-04-2011 09:26 AM
oven not kicking on jojo45822 Oven Repair (including Ranges and Cooktops) 5 12-01-2010 01:45 PM
Fan in oven not kicking in marivet Oven Repair (including Ranges and Cooktops) 0 03-04-2010 09:34 AM
Freezer kicking on and off wdaanx Refrigerator & Freezer Repair 1 10-06-2009 08:30 AM
Fan Motor Kicking Off RJ 456MINK Heating, Ventilation, and Air Conditioning (HVAC) 0 07-15-2009 10:18 AM
