Discuss
It Is So Noisy Everytime It Runs
 in
Dryer Repair
Hi, Can You Help Me With Our Dryer Machine, Everytime It Runs Its Too Noisy. Whenever It Runs As If
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » It Is So Noisy Everytime It Runs
  #1 (permalink)
Old 01-29-2008, 12:59 PM
arnel arnel is offline
Junior Member
arnel is on a distinguished road
Default It Is So Noisy Everytime It Runs
Model Number: DBXR453GVOWW   Brand: GE   Age: 5 - 10 years
Can You Help Me With Our Dryer Machine, Everytime It Runs Its Too Noisy. Whenever It Runs As If The Roller Is Touching Some Kindof Metal That Would Create To Much Noise.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-29-2008, 08:12 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the noise caused by the worn out rear and, possible the front, bearings.
Open the door and remove the screws holding the top panel from the door frame.
Lift the top panel and remove the screw on each side holding the front panel.
Remove the front panel.
Check the front bearings (#313 and 316 on the #5 break down diagram).
Remove the access panel on the back to get access to the belt and idler pulley.
Draw a picture of the belt rolling over the idler and motor pulleys before removing the belt.
Remove the belt. Remove the drum.
- The part number for the rear bearing kit is AP2619300
- The part number for the front bearing is AP3790641
- The part number for the slide (4 used) is AP631382
Here are the break down diagrams for the GE dryer Model DBXR453GV0WW
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Noisy Evap Fan hamm_6869 Refrigerator & Freezer Repair 5 09-19-2008 01:07 PM
Microwave runs and runs wilner5 Microwave Repair 5 12-12-2007 08:50 PM
Very noisy dishwasher im2busy4this Dishwasher Repair 1 09-12-2007 04:54 AM
Noisy Maytag DW Rocky Chiquera Dishwasher Repair 2 07-27-2007 08:08 AM
noisy freezer fan Linda Refrigerator & Freezer Repair 0 07-24-2007 02:37 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
