| » Electric dryer overheats within minutes |
Model Number: 400 series Brand: Kenmore Age: 1 - 5 years
My kenmore 400 dryer overheats and shuts off within 5 minutes. Almost as soon as you turn it on you can smell a burnt wire smell. I have inspected all wiring and connections which are good. The belt is good and so is the motor. The heating element is good as well tested with a meter and visual inspection. I am however getting a reading of between .01 and .05 jumping back and forth on a cycling thermostat at room temperature. I think it should be 0. Would this thermostat be at fault here?
| Display Modes | |
| Electric Dryer, heat cuts off after 1-2 minutes | BobFixx | Dryer Repair | 5 | 05-21-2012 06:04 PM |
| Kenmore Electric Dryer cuts off after running 2/3 minutes | Robert Ferrell | Dryer Repair | 1 | 10-15-2011 03:56 AM |
| HE3 electric dryer stops after 2 minutes - no error code | flylow | Dryer Repair | 0 | 07-29-2011 01:14 PM |
| Electrolux Slide-in electric range overheats | kbrubaker | Oven Repair (including Ranges and Cooktops) | 0 | 09-25-2010 06:35 AM |
| Sears electric dryer overheats | panhandle_papa | Dryer Repair | 0 | 07-20-2010 05:46 PM |
