| » dryer |
Model Number: ler8648pwo Brand: Whirlpool Age: 5 - 10 years
i replaced the motor on my dryer but it still won't engage the heating element turns on but it won't shut off unless you turn the timer off or pull the plug
what should i try next Ads By Google Related Models |
Hi.
Could you, please describe the problem more clearly? Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
Most likely you've got two problems there. One-the thermal fuse is open. Two-the heating element is grounded. Unplug the dryer, remove the back, take both wires off the heater and using the multimeter check each heater's contact to the cabinet. If there is continuity - replace the heater. The thermal fuse Part number: 3392519 The heating element Part number: 279838 Here are the breakdown diagrams and Replacement parts for Whirlpool LER8648PW0 29"ELECTRIC DRYER | AppliancePartsPros.com Post the results. Simon.
__________________
| Display Modes | |
