Discuss
Thermal Cutoff fuse wiring Auestion
 in
Dryer Repair
Hello, I am replacing the thermal cutoff fuse and high limit thermostat kit (Pt. #279769) and my replacement parts differ
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Thermal Cutoff fuse wiring Auestion
  #1 (permalink)
Old 09-21-2009, 07:14 PM
tdubbz02 tdubbz02 is offline
Junior Member
tdubbz02 is on a distinguished road
Default Thermal Cutoff fuse wiring Auestion
Model Number: LEP6848AW1   Brand: Whirlpool   Age: 5 - 10 years
Hello, I am replacing the thermal cutoff fuse and high limit thermostat kit (Pt. #279769) and my replacement parts differ slightly from the original, namely the cutoff fuse. There are two wires a Red/white stripe and solid red that connect to the fuse but I am unsure which of these go to which connector on the new fuse. On the old fuse the connectors where in a left/right setup with the red/white wire on the left connector and red on the left. The new fuse the connectors are in a top/bottom setup with no markings. Anyone have an idea as to where the wires hookup to the new fuse, or does it matter??? Any replies greatly appreciated.
Related Models
Whirlpool LEP6848AW1
Whirlpool LEP6848AW2
Whirlpool LEP7858AN0
Whirlpool LEP7858AN1
Whirlpool LEP7858AN2
Whirlpool LEP7858AQ2
Whirlpool LEP7858AW0
Whirlpool LEP7858AW1
Whirlpool LEP7858AW2
Whirlpool LEP7858AZ2
Frigidaire LEQ1442ES0 Frigidaire/dryer
Frigidaire LEQ2152EE0 Frigidaire/dryer
Frigidaire LEQ2152ES0 Frigidaire/electric Dryer
Frigidaire LEQ332DS0 Frigidaire/dryer
Whirlpool LEQ5000KQ0
Whirlpool LEQ5000KQ1 29"electric Dryer
Whirlpool LEQ5000KQ2 29"electric Dryer
Whirlpool LEQ5000KW1 29"electric Dryer
Whirlpool LEQ5000KW2 29"electric Dryer
Whirlpool LEQ5000PW0 29"electric Dryer
Frigidaire LEQ6000ES0 Frigidaire/dryer
Frigidaire LEQ6000ES1 Frigidaire/dryer
Frigidaire LEQ6000ES2 Frigidaire/electric Dryer
Frigidaire LEQ642DS0 Frigidaire/dryer
Frigidaire LEQ7000EG0 Frigidaire/dryer
Frigidaire LEQ7000ES0 Frigidaire/dryer
Frigidaire LEQ7000ES1 Frigidaire/dryer
Frigidaire LEQ7000ES2 Frigidaire/dryer
Whirlpool LEQ7000KQ0
Whirlpool LEQ7000KQ1
Whirlpool LEQ7000KQ2
Whirlpool LEQ7030KQ0
Whirlpool LEQ7030KQ1
Whirlpool LEQ7030KQ2 29"electric Dryer
Whirlpool LEQ8000HQ0
Whirlpool LEQ8000HQ1
Whirlpool LEQ8000JQ0
Whirlpool LEQ8000JQ1
Whirlpool LEQ8000JQ2
Whirlpool LEQ8000JQ3 29"electric Dryer
Whirlpool LEQ8000JQ4 Electric Dryer
Whirlpool LEQ8100KQ0
Whirlpool LEQ8100KQ1
Whirlpool LEQ8100KT0
Whirlpool LEQ8100KT1
Whirlpool LEQ8611LG0
Whirlpool LEQ8611LG1 27"electric Dryer
Whirlpool LEQ8611LW0
Whirlpool LEQ8611LW1 27"electric Dryer
Whirlpool LEQ8611PG0 27" Electric Dryer
Whirlpool LEQ8611PG1 27"electric Dryer
Whirlpool LEQ8611PG2 27"electric Dryer
Whirlpool LEQ8611PW0 27" Electric Dryer
Whirlpool LEQ8611PW1 27"electric Dryer
Whirlpool LEQ8611PW2 27"electric Dryer
Whirlpool LEQ8621PG0 27" Electric Dryer
Whirlpool LEQ8621PG1 27"electric Dryer
Whirlpool LEQ8621PG2 27"electric Dryer
Whirlpool LEQ8621PW0 27" Electric Dryer
Whirlpool LEQ8621PW1 27"electric Dryer
Whirlpool LEQ8621PW2 27"electric Dryer
Whirlpool LEQ8800JQ0
Whirlpool LEQ8800JQ1
Whirlpool LEQ8800JT0
Whirlpool LEQ8800JT1
Whirlpool LEQ8857HQ0
Whirlpool LEQ8857HQ1
Whirlpool LEQ8857HZ0
Whirlpool LEQ8857HZ1
Whirlpool LEQ8857JQ0
Whirlpool LEQ8857JQ1
Whirlpool LEQ8857JT0
Whirlpool LEQ8857JT1
Whirlpool LEQ8858HQ0
Whirlpool LEQ8858HQ1
Whirlpool LEQ8858HZ0
Whirlpool LEQ8858HZ1
Whirlpool LEQ8858JQ0
Whirlpool LEQ8858JQ1
Whirlpool LEQ8858JT0
Whirlpool LEQ8858JT1
Whirlpool LEQ8858JZ0
Whirlpool LEQ8858JZ1
Whirlpool LEQ9030PQ0 29"electric Dryer
Whirlpool LEQ9030PQ1 29" Electric Dryer
Whirlpool LEQ9508KQ0
Whirlpool LEQ9508LG0
Whirlpool LEQ9508LW0
Whirlpool LEQ9508LW1 29"electric Dryer
Whirlpool LEQ9508PG0 29"electric Dryer
Whirlpool LEQ9508PG1 29" Electric Dryer
Whirlpool LEQ9508PW0 29"electric Dryer
Whirlpool LEQ9508PW1 29" Electric Dryer
Whirlpool LEQ9557KQ1
Whirlpool LEQ9557KT1
Whirlpool LEQ9558KQ0
Whirlpool LEQ9558KQ1
Whirlpool LEQ9558KT0
Whirlpool LEQ9558KT1
Whirlpool LEQ9857LG0
Whirlpool LEQ9857LG1 29"electric Dryer
Whirlpool LEQ9857LW0
Whirlpool LEQ9857LW1 29"electric Dryer
Whirlpool LEQ9857PW0 29"electric Dryer
Whirlpool LEQ9858LG0
Whirlpool LEQ9858LG1 29"electric Dryer
Whirlpool LEQ9858LW0
Whirlpool LEQ9858LW1 29"electric Dryer
Whirlpool LEQ9858PG0 29"electric Dryer
Whirlpool LEQ9858PG1 29"electric Dryer
Whirlpool LEQ9858PW0 29"electric Dryer
Whirlpool LEQ9858PW1 29"electric Dryer
Whirlpool LEQ9957KQ0
Whirlpool LEQ9957KT0
Admiral LER1115AAW Range - F/s Std Ele
Whirlpool LER2614BW0
Whirlpool LER2614BW1
Whirlpool LER2614BW2
Whirlpool LER2614DW0
Whirlpool LER2614DW1
  #2 (permalink)
Old 09-21-2009, 07:51 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default
Maybe these photos will help:
1. Hi Limit (small limit upper right hand side of this pic)
the most frequent problem if dryer RUNS but no heat.
2. Heater assembly. 7. Control thermostat(s).
5. Fuse(350F), if blown(open) the dryer will NOT run. 4. Heater element.
Lets look closer at that heater assembly:
The small limit on the top(300F) will blow if the duct is stopped up
The bottom fuse is its cousin(250F), they are partners in crime.
When one fails both are bad and both come in a kit. The dryer
will however run even if these guys are open(bad).
Clogged outside vent
You will need to bust the dryer open to get to all of the lint,
inspect the rollers and belt. Start by yanking out the filter.
Remove those 2 phillips screws in the top of the filter housing so you can pop the top.
Get the screws out that hold the front panel on. Important: lift UP the front panel to release the lower clips to prevent them from breaking! Get the drum out. Oil the rollers and idler assembly,
Vacuum it all out real good. Oil the Idler using non-flammable, high temperature
resistance, zoomspout oil. (ace hardware $3).
Here is a good shot of how the belt ought to look all propah like:
As you can see the belt goes between the idler . Insert the idler into the floor and yank
upwards, loop the belt through the idler and over the motor pully. This creates tension.
NOTE: If you have a friend hold the drum up for you while you install the belt it is much
easier. Be sure the belt is not twisted or when you start the dryer the belt will be cut in two.
Here is a DOT dryer manual that features moisture sensing control.:
  #3 (permalink)
Old 09-21-2009, 08:10 PM
Junior Member
Default
Thanks for the pics and the response. I already have the parts I need and am in the process of installing them. My issue is my replacement thermal cutoff fuse differs slightly from the original in that its connectors are in an top/bottom fashion and the original are in a left/right setup. My question is in regards to the connecting wires, on the original fuse a red/white stripe wire connected to the left connector and a solid red wire to the right connector, now which of these wires should connect to the top connector and which to the bottom connector on the new fuse, or does it matter?
  #4 (permalink)
Old 09-21-2009, 08:33 PM
Senior Expert
APP Volunteer
Default
All you is doing is getting continuity out the limit. You cannot connect it backward but you want to make sure it does not ground to the frame or heat chamber. Sometimes you need the exact replacement to make it connect properly.
  #5 (permalink)
Old 09-21-2009, 08:55 PM
Junior Member
Default
Ok, here is a pic of the original thermal cutoff and the replacement that came with the kit. The original on the left as a left/right connector setup and the replacement a top/bottom setup. They are pictured exactly how the bolt to the dryer. The original had a red/white stripe wire connected to the left connect post and a solid red wire on the right connect post. My question is which of these wires connect to the top connect post and which connect to the bottom post of the new replacement? Or if it matters?
  #6 (permalink)
Old 09-22-2009, 05:00 AM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Quote:
Or if it matters?
It does not matter.
__________________
John Pahl
ApplianceJunk.com
ApplianceDigest.com
  #7 (permalink)
Old 09-22-2009, 09:38 AM
Senior Expert
APP Volunteer
Default
It does not matter. If that one keeps going out it is a sign of a stopped up vent
  #8 (permalink)
Old 09-22-2009, 02:26 PM
Junior Member
Default
Thank you so much for the help SublimeMasterJW and ApplianceJunk! So far so good the dryer is heating again, thanks again, much appreciated!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermal Fuse sweetliberty Dishwasher Repair 6 10-01-2009 11:59 AM
Replacing 279816 thermal cutoff kit warrengigi Dryer Repair 24 08-10-2009 05:34 PM
thermal cutoff jphelps Dryer Repair 1 08-20-2008 08:57 AM
Help with Replacing Thermal Cutoff Kit ReagaNoah Dryer Repair 4 08-16-2008 04:17 PM
Thermal Cutoff Kit macoca2005 Dryer Repair 1 08-11-2008 08:00 PM
