Discuss
Burnt Resistors on Control Board
 in
Dryer Repair
Symptoms: Tripped circuit breakers (double 30 Amp breakers). Since everything seemed fine with the dryer, tested the circuit breakers and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Burnt Resistors on Control Board
  #1 (permalink)
Old 09-21-2009, 01:40 PM
Junior Member
h2homem is on a distinguished road
Default Burnt Resistors on Control Board
Model Number: MDE5500AYW   Brand: Maytag   Age: 5 - 10 years
Symptoms: Tripped circuit breakers (double 30 Amp breakers). Since everything seemed fine with the dryer, tested the circuit breakers and found that they are tripping at about 23-24 Amps, not the 30 Amps at which they are rated. Upon closer inspection of the dryer, found that resistors R53, R54, R55, R56 on control board show browning/burning. Everything else checks out fine. What could be causing both the circuit breakers to read lower and the dryer control board resistors to burn?
Thanks.
Related Models
Maytag MDE5500AYW DRYER- ELE
Maytag MDE5500AZQ DRYER- ELE
Maytag MDE5500AZW DRYER- ELE
Maytag MDE5806AYK DRYER- ELE
Maytag MDE5806AYW DRYER- ELE
Maytag MDE5806AZK DRYER- ELE
Maytag MDE5806AZW DRYER- ELE
Maytag MDE5960AYW DRYER- ELE
Maytag MDE6000AUW DRYER- ELE
Maytag MDE6000AYQ DRYER- ELE
Maytag MDE6000AYW DRYER- ELE
Maytag MDE6000AZQ DRYER- ELE
Maytag MDE6000AZW DRYER- ELE
Maytag MDE6200AYQ DRYER- ELE
Maytag MDE6200AYW DRYER- ELE
Maytag MDE6200AZQ DRYER- ELE
Maytag MDE6200AZW DRYER- ELE
Maytag MDE6400AGW DRYER- ELE
Maytag MDE6400AYQ DRYER- ELE
Maytag MDE6400AYW DRYER- ELE
Maytag MDE6400AZW DRYER- ELE
Maytag MDE6460AYW DRYER- ELE
Maytag MDE6460AZW DRYER- ELE
Maytag MDE6657BYQ DRYER- ELE
Maytag MDE6657BYW DRYER- ELE
Maytag MDE6700AYW DRYER- ELE
Maytag MDE6700AZW DRYER- ELE
Maytag MDE6800AYQ DRYER- ELE
Maytag MDE6800AYW DRYER- ELE
Maytag MDE6800AZQ DRYER- ELE
Maytag MDE6800AZW DRYER- ELE
Maytag MDE7057AYQ DRYER- ELE
Maytag MDE7057AYW DRYER- ELE
Maytag MDE7057AZW DRYER- ELE
Maytag MDE7400AYQ DRYER- ELE
Maytag MDE7400AYW DRYER- ELE
Maytag MDE7400AZQ DRYER- ELE
Maytag MDE7400AZW DRYER- ELE
Maytag MDE7460AYQ DRYER- ELE
Maytag MDE7460AYW DRYER- ELE
Maytag MDE7500AYQ DRYER- ELE
Maytag MDE7500AYW DRYER- ELE
Maytag MDE7500AZQ DRYER- ELE
Maytag MDE7500AZW DRYER- ELE
Admiral MDE7550AGW DRYER- ELE
Maytag MDE7600AUW DRYER- ELE
Maytag MDE7600AYQ DRYER- ELE
Maytag MDE7600AYW DRYER- ELE
Maytag MDE7600AZQ DRYER- ELE
Maytag MDE7600AZW DRYER- ELE
Maytag MDE7657AYQ DRYER- ELE
Maytag MDE7657AYW DRYER- ELE
Maytag MDE7657BYQ DRYER- ELE
Maytag MDE7657BYW DRYER- ELE
Maytag MDE7658AYQ DRYER- ELE
Maytag MDE7658AYW DRYER- ELE
Maytag MDE7658BYQ DRYER- ELE
Maytag MDE7658BYW DRYER- ELE
Maytag MDE7757AYQ DRYER- ELE
Maytag MDE7757AYW DRYER- ELE
Maytag MDE7758AYQ DRYER- ELE
Maytag MDE7758AYW DRYER- ELE
Maytag MDE8000AYQ DRYER- ELE
Maytag MDE8000AYW DRYER- ELE
Maytag MDE8000AZW DRYER- ELE
Maytag MDE8057AYQ DRYER- ELE
Maytag MDE8057AYW DRYER- ELE
Maytag MDE8057AZW DRYER- ELE
Maytag MDE8058AYQ DRYER- ELE
Maytag MDE8058AYW DRYER- ELE
Maytag MDE8400AYQ DRYER- ELE
Maytag MDE8400AYW DRYER- ELE
Maytag MDE8400AZW DRYER- ELE
Maytag MDE8416AYA DRYER- ELE
Maytag MDE8416AYW DRYER- ELE
Admiral MDE8426AAW DRYER- ELE
Admiral MDE8426AGW DRYER- ELE
Maytag MDE8500AYW DRYER- ELE
Maytag MDE8506AYA DRYER- ELE
Maytag MDE8506AYW DRYER- ELE
Maytag MDE8506AZW DRYER- ELE
Admiral MDE8550AGW DRYER- ELE
Admiral MDE8550BGW DRYER- ELE
Maytag MDE8600AYQ DRYER- ELE
Maytag MDE8600AYW DRYER- ELE
Maytag MDE8600AZQ DRYER- ELE
Maytag MDE8600AZW DRYER- ELE
Maytag MDE8757AYQ DRYER- ELE
Maytag MDE8757AYW DRYER- ELE
Maytag MDE9206AYA DRYER- ELE
Maytag MDE9206AYW DRYER- ELE
Maytag MDE9206AZW DRYER- ELE
Maytag MDE9306AUW DRYER- ELE
Maytag MDE9306AYA DRYER- ELE
Maytag MDE9306AYW DRYER- ELE
Maytag MDE9306AZA DRYER- ELE
Maytag MDE9306AZW DRYER- ELE
Maytag MDE9316AYA DRYER- ELE
Maytag MDE9316AYQ DRYER- ELE
Maytag MDE9316AYW DRYER- ELE
Maytag MDE9316AZW DRYER- ELE
Maytag MDE9357AYA DRYER- ELE
Maytag MDE9357AYW DRYER- ELE
Maytag MDE9360AYW DRYER- ELE
Maytag MDE9390AYW DRYER- ELE
Maytag MDE9390AZW DRYER- ELE
Maytag MDE9420AYW DRYER- ELE
Maytag MDE9420AZW DRYER- ELE
Maytag MDE9520AYQ DRYER- ELE
Maytag MDE9520AYW DRYER- ELE
Maytag MDE9520AZW DRYER- ELE
Maytag MDE9557AYA DRYER- ELE
Maytag MDE9557AYQ DRYER- ELE
Maytag MDE9557AYW DRYER- ELE
Maytag MDE9557AZA DRYER- ELE
Maytag MDE9557AZQ DRYER- ELE
Maytag MDE9557AZW DRYER- ELE
Maytag MDE9606AUW DRYER- ELE
Maytag MDE9606AYA DRYER- ELE
Maytag MDE9606AYQ DRYER- ELE
  #2 (permalink)
Old 09-21-2009, 02:30 PM
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Quote:
Thanks.
If the breaker is tripping at 24 amps then you most likely have
a weak breaker and need to replace it.
  #3 (permalink)
Old 09-21-2009, 02:34 PM
Junior Member
Default
Sure. Will do. Any idea why the resistors on the dryer control board are showing browning/burning?
  #4 (permalink)
Old 09-21-2009, 02:41 PM
Senior Expert
APP Volunteer
Default
Are you talking about this?
  #5 (permalink)
Old 09-21-2009, 03:08 PM
Junior Member
Default
Exactly! Looks like an actual picture of my controller...
  #6 (permalink)
Old 09-21-2009, 03:27 PM
Senior Expert
APP Volunteer
Default
If this is the case this isn't related to your breaker tripping.
I think you are seeing discoloration due to the fact that they get
fairly warm. I don't think you are looking at a fire hazard here
if that's what you are concerned about. I believe the worst
that happens with this is that you eventually loose the sensor
dry function or get erratic timer function when these fail. Notice
on the right that the resistors look different. Maytag made some
changes on this setup notice that the resistors on the right
look different. That's because they are made of a different
composition that can tolerate more heat than the others.
  #7 (permalink)
Old 09-21-2009, 04:52 PM
Junior Member
Default
Thank you very much!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need to replace burnt out control panel leipard Oven Repair (including Ranges and Cooktops) 1 02-16-2010 07:22 AM
Need to replace burnt out control panel leipard Dishwasher Repair 2 02-16-2010 04:59 AM
scorched resistors scottsaunders Dryer Repair 11 01-15-2010 02:39 AM
whirlpool double oven control board burnt out? nevadamike Oven Repair (including Ranges and Cooktops) 0 12-25-2009 05:25 PM
BURNT Dishwasher control board - replace? Jerry_in_VA Dishwasher Repair 0 06-08-2009 05:51 AM
