Hi All,
Roper dryer, RGL4622 DL0, blew out circuit breaker. Got circuit back on. Arced and burned out receptacle when plugged in (had to replace it.) and burned one plug prong and ground prong of dryer. Door switch and start button seem fine. (checked with ohm meter) Timer conducts (checked with ohm meter on power plug) when not in the off position.
Also examined wiring, found no damage. Any input would be appreciated.
Thank you,
