| » GE Dryer won't get very hot, takes 2 hrs |
My experience with the basic GE dryers is that the heating element breaks a lot. Sometimes you cannot see it, so brush it off with your hand and check it with a meter.
Also, make sure the blower and internal venting is clear, they tend to get obstructed with lint.
__________________
OK. I cleared some lint behind the heat deflector, I'll see if that helps. One of the elements looked a lot better (newer) than the other, leading me to believe that the other one isn't turning on. How do I check it with a meter, just for continuity, or should it resist a specific amount of ohms?
Thanks so much Paul |
A continuity check is the same as a resistance check. You should have a tech sheet under the console which will give the specs, if not look for between 10 and 20 ohms resistance. Also, make sure no part of the coil is touching the metal frame.
Good luck
__________________
| Display Modes | |
| My dryer takes to long to dry | sandraquin | Dryer Repair | 1 | 10-06-2009 09:23 AM |
| Dryer takes long to Dry | StarA82 | Dryer Repair | 1 | 10-05-2009 04:09 AM |
| dryer takes 2 or 3 cycles to dry | Photoplay1 | Dryer Repair | 2 | 06-08-2009 05:07 AM |
| Dryer takes to long to dry | Julito | Dryer Repair | 1 | 12-05-2007 12:10 PM |
| Dryer Takes way to long to dry | confused | Dryer Repair | 4 | 08-12-2007 08:38 PM |
