| » Dryer motor hums & will not turn |
Model Number: LGN2000JQ2 Brand: Whirlpool Age: 1 - 5 years
My gas dryer will not turn/spin. I checked the timer (OK), door switch (OK), fuse (OK). Removed panels and cleaned everything (it was dirty). When I hit the ON button the motor trys to turn (humming sound - I guess it dosen't know the words) but seens to be bound up. I tryed helping the tub to turn by hand (opened the door and spun the tub with the door switch depressed) but it did not help. The tub does not spin very freely when pushed by hand (lots of resistance).
I suspect the motor is shot. Please advise. Kind Regards, Mike Ads By Google Related Models |
Hi Mike,
Remove the belt and check if the motor moves freely. If it does not - replace the motor. - The part number for the motor is AP3094245 Here are the break down diagrams for the Whirlpool dryer Model LGN2000JQ2 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Thank you so much for the links above. Using them I was able to fix my brother's broken dryer with ease.
I was going to take apart the whole machine from the back, but that site saved me. In ten minutes I was able to take apart the entire machine and determine the belt was broken but motor worked fine. Replaced broken belt, and upgraded pulley to wheel-type. Total time under 30 minutes Thanks again! J-ME |
| Display Modes | |
| New Dryer Motor Won't Turn | scottymaker | Dryer Repair | 1 | 10-21-2009 10:05 AM |
| dryer won't turn on only hums and shuts off | karen klomsten | Dryer Repair | 3 | 10-01-2009 05:38 PM |
| Dryer motor just hums | Pottspd | Dryer Repair | 3 | 03-09-2009 12:51 PM |
| motor hums but drum will not turn | judy71635@alltel.net | Dryer Repair | 1 | 07-30-2008 08:28 PM |
| Gas dryer motor hums but won't start | nonqual | Dryer Repair | 5 | 12-27-2007 04:40 AM |
