Discuss
Whirlpool Dryer Disassembly
 in
Dryer Repair
Dryer has begun making noise. On last load there was no (or very little) heat. Removed back to examine and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer Disassembly
  #1 (permalink)
Old 09-20-2009, 03:32 PM
Junior Member
JNagarya is on a distinguished road
Default Whirlpool Dryer Disassembly
Model Number: LXE4900   Brand: Whirlpool   Age: More than 10 years
Removed back to examine and there is substantial heat, so it doesn't seem there's any problems with heating element. Cleaned out all accessible lint.
The noise: cursory research suggests the cause might be loose/worn drum rollers. How do I disassemble this model to check that?
Any other suggestions as to possible causes of indicated problems?
Thanks.
Ads By Google
Related Models
Whirlpool LXE4900W0
Whirlpool LXE4900W1
Whirlpool LXE4920W0
Whirlpool LXE5500W0
Whirlpool LXE5500W1
Whirlpool LXE5500W2
Whirlpool LXE5520W0
Whirlpool LXE5700W0
Whirlpool LXE5720W0
Whirlpool LXE6300W0
Whirlpool LXE6440W0
Whirlpool LXE6440W1
Whirlpool LXE6700W0
Whirlpool LXE6700W1
Whirlpool LXE6700W2
Whirlpool LXE6720W0
Whirlpool LXE7400W0
Whirlpool LXE7500W0
Whirlpool LXE7800W0
Whirlpool LXE7800W1
Whirlpool LXE7800W2
Whirlpool LXE7800W3
Whirlpool LXE8700W0
Whirlpool LXE8800W0
Whirlpool LXE9920W0
Whirlpool LXE9920W1
Whirlpool LXG6571W0
Whirlpool LXG6571W1
Whirlpool LXG6571W2
Whirlpool LXG7401W0
Whirlpool LXG7871W0
Whirlpool LXI4911W0
Whirlpool LXI4921W0
Whirlpool LXI5501W0
Whirlpool LXI5501W1
Whirlpool LXI5501W2
Whirlpool LXI5521W0
Whirlpool LXI5521W1
Whirlpool LXI5701W0
Whirlpool LXI5721W0
Whirlpool LXI6301W0
Whirlpool LXI6441W0
Whirlpool LXI6441W1
Whirlpool LXI6701W0
Whirlpool LXI6701W1
Whirlpool LXI6701W2
Whirlpool LXI6721W0
Whirlpool LXI6901W1
Whirlpool LXI7401W0
Whirlpool LXI7501W0
Whirlpool LXI7801W0
Whirlpool LXI7801W1
Whirlpool LXI7801W2
Whirlpool LXI7801W3
Whirlpool LXI8701W0
Whirlpool LXI8801W0
Whirlpool LXI9921W0
Whirlpool LXI9921W1
Whirlpool LXR5232JQ0
Whirlpool LXR5232JQ1
Whirlpool LXR5432KQ0
Whirlpool LXR5432KQ1 Automatic Washer
Whirlpool LXR6232EQ0
Whirlpool LXR6432JQ0
Whirlpool LXR6432JQ1
Whirlpool LXR6432JQ2 Automatic Washer
Whirlpool LXR6432JQ3 Automatic Washer
Whirlpool LXR7133JQ0
Whirlpool LXR7133JQ1
Whirlpool LXR7144EQ0
Whirlpool LXR7144EQ1
Whirlpool LXR7144EQ2
Whirlpool LXR7144EW0
Whirlpool LXR7144EW1
Whirlpool LXR7144EZ0
Whirlpool LXR7144EZ1
Whirlpool LXR7144EZ2
Whirlpool LXR7244JQ0
Whirlpool LXR7244JQ1
Whirlpool LXR7244JQ2 Automatic Washer
Whirlpool LXR7244JT0
Whirlpool LXR7244JT1
Whirlpool LXR7244JT2 Automatic Washer
Whirlpool LXR7244JZ0
Whirlpool LXR7244JZ1
Whirlpool LXR7244PQ0 Automatic Washer
Whirlpool LXR7244PQ1 Automatic Washer
Whirlpool LXR7244PQ3 Automatic Washer
Whirlpool LXR7244PQ4 Automatic Washer
Whirlpool LXR7244PT0 Automatic Washer
Whirlpool LXR7244PT1 Automatic Washer
Whirlpool LXR7244PT3 Automatic Washer
Whirlpool LXR7244PT4 Automatic Washer
Whirlpool LXR9200HQ0
Whirlpool LXR9200HQ1
Whirlpool LXR9245EQ0
Whirlpool LXR9245EQ1
Whirlpool LXR9245EQ2
Whirlpool LXR9245EW0
Whirlpool LXR9245EW1
Whirlpool LXR9245EZ0
Whirlpool LXR9245EZ1
Whirlpool LXR9245EZ2
Whirlpool LXR9445JQ0
Whirlpool LXR9445JQ1
Whirlpool LXR9445JT0
Whirlpool LXR9445JT1
Frigidaire M05A Frg(v1) / Chest Freezer
Frigidaire M05B Frg(v2) / Chest Freezer
Frigidaire M08A Frg(v1) / Chest Freezer
Frigidaire M08B Frg(v2) / Chest Freezer
Amana M1020E Mwave - Cntrtp / Stand Alone
Amana M1020W Mwave - Family Size (60 Hz)
Amana M1031E Mwave - Family Size (60 Hz)
Amana M1031W Mwave - Family Size (60 Hz)
Magic Chef M1100 Mwave - Cntrtp / Stand Alone
Jenn-Air M120 Mwave - Cntrtp / Stand Alone
Jenn-Air M124 Mwave - Cntrtp / Stand Alone
  #2 (permalink)
Old 09-23-2009, 08:11 AM
Senior Expert
APP Volunteer
sidfink43 will become famous soon enough
Default
You need to take off the blower wheel cover and inspect it to see if it is clogged or broken.
I have not worked on a machne this old recently, but I think you can access the rollers by releasing the top from the cabinet by inserting a screw driver or putty knife in the gap between the top and the front near the edges and flipping up the top. You can then take off the front and release the belt and remove the drum. This will get you to the rollers.
__________________
  #3 (permalink)
Old 09-23-2009, 11:23 AM
Junior Member
Default Whirpool Dryer Disassembly
It appears the top is held onto the front and side panel/s by screws (weirdly: one would have to have a mighty short screwdriver, as they are within the "lip" area).
There are two sheets of illustration online here, one an exploded view of the "bulkhead," the other an exploded view of the cabinet. Unfortunately, as I've never done any equivalent repairs, and haven't been inside this dryer except for removing the back panel, I'm not able to make head or tail of it as concerns getting inside the cabinet in order to take a look.
And it doesn't appear by the ilustraions that one would remove the bottom.
  #4 (permalink)
Old 09-23-2009, 12:33 PM
Senior Expert
APP Volunteer
Default
The diagrams really do not show exactly how to get inside, and when I look on other sites they don't list this model at all.
All I can say is that you need to remove the front at a minimum and release the belt and the drum will come out.
__________________
  #5 (permalink)
Old 09-23-2009, 03:35 PM
Junior Member
Default
I'm wondering: Note in one of the diagrams a triangular piece ("gusset" in the parts list) at the top left of the "bulkhead". I'm wondering if it works as a hinge -- with another at the bottom corner -- so that the "bulkhead" swings out.
  #6 (permalink)
Old 06-26-2011, 09:14 AM
Junior Member
DorkyDan is on a distinguished road
Default Top Removal on Dryers
I am having the SAME problem with my RCA/GE dryer. So far I can't
figure out HOW you're supposed to RELEASE the lid from the case.
If you DO find out, please share this as I'm sure this is a common problem.
Although I never had this problem with older dryers I've repaired.
dorkydan
  #7 (permalink)
Old 06-26-2011, 01:22 PM
Senior Expert
APP Volunteer
Default
If you will post a model number we can see exactly what you have. Normally the top will come off after you remove the screws on the top of the door jam.
__________________
  #8 (permalink)
Old 06-26-2011, 01:57 PM
Junior Member
Default Removing TOP from RCA/GE Electric Dryer
Model Number is: BVLR333EVOWW
I have felt around the inside of the door, and can see NO screws. Should I look inside with a mirror perhaps? Where are these screws located? And how do you get to the "top of the door jam"??
Do I need to crawl inside the opening of the door to SEE them?
DorkyDan
Quote:
  #9 (permalink)
Old 06-26-2011, 02:39 PM
Senior Expert
APP Volunteer
Default
If you open the dryer door and look at the top of the jamb you should see screws going into the top of the dryer. They are number 233 in this diagram
Front panel & door replacement parts for General Electric BVLR333EV0WW Electric dryer | AppliancePartsPros.com
and will either be phillips or hex head.
If there is some other design then I am not familiar with it on a GE dryer model.
__________________
  #10 (permalink)
Old 06-26-2011, 06:08 PM
Junior Member
Default Followup Problem
I found the screws, got the top off and checked continuity. All three thermostats and heating elements ALL checked good. So, I turned it on, with the top still off. It started fine, and even put out heat.
New problem: when I walked around it to open the dryer door, I bumped the control panel. There was a spark ... and the dryer quit. It will now not start.
I checked the fuse box, amd reset it.
The diagram in the back of the dryer shows a "Safety" and it also says "RESETABLE". I'm assuming this must be a safety fuse ... but I can't find it in the parts list on here. Do you have ANY idea if there's a satety fuse or cutoff switch ... that will keep the entire dryer from starting ... turning or heating. It's not doing anything now.
I checked continuity again of the thermostats, heating element, and the start switch. ALL are good.
I NEED HELP in determing WHAT to check NEXT ... or where that safety switch/fuse would be located.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
agitator disassembly hand d man Washer Repair 3 11-23-2009 05:30 PM
disassembly andymu Washer Repair 3 10-03-2009 10:07 AM
Disassembly wstronks Dryer Repair 0 04-25-2009 06:25 AM
Dryer disassembly P Bourey Dryer Repair 1 04-24-2009 04:53 PM
GE Triton XL Disassembly ? m1wr Dishwasher Repair 0 12-14-2008 04:32 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
