Replacement parts for WED4800XQ models | AppliancePartsPros.comSee the attachment for the wiring diagram.
Could be a power problem.
The heating coil runs off of 240 volts but on this unit so does the timer motor.
Set the unit to a mid scale heat cycle.
Does the timer advance?
If yes then you have 240 volts so I would start by checking the heating coil.
Often you can see the break. If it looks OK then I would get a meter, see below.
If no then you probably have a power problem, see below.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!![/COLOR]
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
[COLOR="Blue"]
Leadunham Unless your unit is the same model, please start you own thread using "Post New Topic".
Hijacking angeldevil1998 post will just confuse things.[/COLOR]
