| » High pitched squeak |
Model Number: FDE436RES1 Brand: Frigidaire Age: More than 10 years
Dryer makes high-pitched squeak at start of tumble then stops. Makes noise sometimes during tumble, and always just before dryer is about to stop. Could this be a belt? Dryer was given to me and I don't have a manual for it.
Replacement parts for FRIGIDAIRE FDE436RES1 | AppliancePartsPros.com Here is a good site with basic dryer repair help http://www.applianceaid.com/dryers.html Here is the Frigidaire website, where you should be able to get manuals or at least one that is a close match to your unit, if you want them. Search using FDE436 http://www.frigidaire.com/manuals Could this be a belt? I doubt it More likely it is the rear drum support bearing. May need cleaning and re-greasing using a high temp grease. May also need replacing if it is worn. Note the ball bearing (Item 5 in the Cabinet/drum section) likes to take off and hide so be careful when removing it's retainer. Other possibilities are the belt's idler wheel, the front glides or the motor itself.
__________________
| Display Modes | |
| dryer high pitched noise | DEG 3 | Dryer Repair | 0 | 10-22-2009 02:59 PM |
| dryer -high pitched noise | mscerbak | Dryer Repair | 1 | 01-21-2009 05:26 AM |
| High pitched squealing noise | b428337 | Dryer Repair | 3 | 10-06-2008 02:41 PM |
| high pitched noise | Raleigh | Dishwasher Repair | 1 | 12-20-2007 06:35 AM |
| High Pitched squeak in Dryer - AMANA | Tmcjury | Dryer Repair | 0 | 11-06-2007 11:23 AM |
