Our dryer is inconsistently heating. I checked continuity on the fuse and thermostats last week, and removed the vent pipes to check for blockages - checked the external house flap - all is clear and clean. Ignitor will go on and gas will ignite flame, but does not stay on through cycle. Is this a coil issue or is there a way to check if a coil is good/bad? Any other ideas?
