| » dryer stops running |
Model Number: 66812690 Brand: Kenmore Age: More than 10 years
dryer stops running after 5 minutes and circuit breaker is tripped. When problem first started dryer would run for 15-20 minutes before tripping circuit breaker. Is it the dryer, receptacle, cord or circuit breaker?
Yes, although I just tried it on a different heat setting with only 1 towel in it and the time seemed even shorter-only ran for 2 1/2 minutes. If I am reading articles correctly, the dryer should be running on 2 different circuits. In my case, only 1 circuit is tripping.
Quote:
to find out how much amperage this unit is drawing from the outlet. Typically an electric dryer pulls about 24-26 amps from (what should be) its 30 amp breaker. If the amperage checks OK then to you have a problem with your service, maybe a bad circuit breaker. |
| Display Modes | |
| Dryer stops running | Ricky50 | Dryer Repair | 7 | 05-02-2012 04:29 PM |
| Whirlpool Dryer Stops After Running 5 Minutes | beverlyjean | Washer Repair | 4 | 05-18-2009 04:42 PM |
| Roper dryer stops running | NcTarHeel704 | Dryer Repair | 1 | 03-01-2009 05:30 PM |
| Dryer stops running when hot | ccre3 | Dryer Repair | 0 | 12-09-2008 09:10 PM |
| Dryer stops running | den123 | Dryer Repair | 1 | 11-10-2008 05:16 AM |
