shabaka
#1 Posted : Tuesday, August 7, 2012 7:09:48 PM(UTC)
shabaka
the heating on my crosley dryer stop working, it don't get hot anymore, can you please help me to fix my problem? Thank you.
#2 Posted : Wednesday, August 8, 2012 1:49:37 AM(UTC)
Here are your parts, includes a wiring diagram.
Replacement parts for Crosley CDE6000W DRYER- ELE | AppliancePartsPros.com
I am assuming the unit runs, just does not heat.
I would start by checking the power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Next check the heating coil, should be around 12 ohms.
Then check the thermostat, then the safety thermostat, both should be 0 ohms.
If the safety thermostat is blown add this to your post as there are other things that should be checked before replacing it.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Refrigerator problem, Need help please. (Refrigerator & Freezer Repair)
by jbyoung 8/9/2011 3:52:06 PM(UTC)
I have a oven that has quit working and need help please (Oven Repair (including Ranges and Cooktops))
by bunny231426 1/22/2011 6:42:48 PM(UTC)
Not getting any Power-Need Help Please (Washer Repair)
by nydutchmaster22 1/8/2010 3:41:58 PM(UTC)
D'oh!! Stupid Dishwasher! Need help please. (Dishwasher Repair)
by taterchips 6/1/2009 11:22:31 AM(UTC)
Need Help Please (Dishwasher Repair)
by fergie02 3/7/2009 5:19:17 PM(UTC)
Washer is flooding. Need help please! (Washer Repair)
by IrishCatholic 2/20/2009 9:00:59 AM(UTC)
Need help please (Washer Repair)
by Nlee788 12/11/2008 8:02:01 PM(UTC)
