John
Hi, ok to the point, I'm a Electronic tech and have 30 plus years. so I am up on most thing. My dryer doesn't heat, I changed the heating element and both thermal fuses.I have 110vac at both L1 and L2.My Temp Selector on low is .001 ohms, medium is 1.90 ohms , and high is total open. ( now this should still produce some heat on medium right, Also my timer motor is only 13 kohms instead of 1800 to 2900 ohms. So I know the timer motor is shot.Ok I have 110vac on bk and R of the timer thur the cut off at 325 degrees. also coming out to the operating thermostat then to the high limit. All seem to be fine but I'm only getting 115 vac at the heater. Now if I'm reading the diagram right I should be picking up L2( red) 115 on the other side of the heater. Can you give me a hint. Thanks
A model number may help others help you.
How did you check the voltage at the heating coil? Was the dryer running? Was the timer mid scale in a heat mode? On most units one side of the heater is connected to the thermostats, the thermal fuse, the thermal cut-off and a set of timer contacts to L1. Normally you will see 115 volts (L1) there when the unit is at mid scale in a heating mode even when the dryer is not running. You will of coarse also see it on both sides of the heater if the coil is OK. The L2 side of the line is switched in by a centrifugal switch on the motor. It closes when the motor gets close to operating speed. It ensures that the heater does not come on until there is air flow. I am assuming that the unit keeps running after you release the start switch. If it does not then it could be a mechanical problem with the centrifugal mechanism on the motor, as there is a second centrifugal switch which also closes and makes a parallel circuit path around the start switch. It also disconnects the motor's start winding which would cause the motor to over-heat if left in circuit. Could be it is just clogged up with dirt. When you checked the power did you check for 240 volts L1 to L2? Just checking for a 120 using Neutral is no good as you have no way of telling what phase the power is without an 0-scope. |
| All times are GMT -7. The time now is 06:32 PM. |
