Discuss
cling sound in the dryer after it sized
 in
Dryer Repair
Drying was operating and then siezed and stoped. I manually turned the drum a few times. It operates again, making
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » cling sound in the dryer after it sized
  #1 (permalink)
Old 09-20-2009, 05:29 AM
Junior Member
Schaffer is on a distinguished road
Default cling sound in the dryer after it sized
Model Number: ler8875rqi   Brand: Whirlpool   Age: 5 - 10 years
Drying was operating and then siezed and stoped. I manually turned the drum a few times. It operates again, making a "clinging" and scratchy sound. belt? bearing? I'm clueless. Please suggest a diagnosis and a method of repair. Thank you.
I should add that when the original siezing occurred the load was small, a table cloth and a pair of tennis shoes.
Ads By Google
Related Models
Amana LES10AW Washer - Top Loading
Amana LES19AW Dryer - Gas
Amana LES33AW Dryer - Gas
Amana LES34AW Washer - Top Loading
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Amana LET-480 Range - S/c S/i Ddraft Gas
Amana LET-480A Range - S/c S/i Ddraft Gas
Amana LET-480B Range - S/c S/i Ddraft Gas
Amana LET-480C Range - S/c S/i Ddraft Gas
Whirlpool LET5434AN0
Whirlpool LET5434AQ0
Whirlpool LET5434AW0
Whirlpool LET5436AN0
Whirlpool LET5436AW0
Whirlpool LET5624BN0
Whirlpool LET5624BN1
Whirlpool LET5624BN2
Whirlpool LET5624BQ0
Whirlpool LET5624BQ1
Whirlpool LET5624BQ2
Whirlpool LET5624BW0
Whirlpool LET5624BW1
Whirlpool LET5624BW2
Whirlpool LET5624DQ0
Whirlpool LET5624DQ1
Whirlpool LET6634AN0
Whirlpool LET6634AN1
Whirlpool LET6634AN2
Whirlpool LET6634AQ0
Whirlpool LET6634AQ1
Whirlpool LET6634AQ2
Whirlpool LET6634AW0
Whirlpool LET6634AW1
Whirlpool LET6634AW2
Whirlpool LET6634DQ0
Whirlpool LET6634DQ1
Whirlpool LET6634DZ0
Whirlpool LET6634DZ1
Whirlpool LET6638AN0
Whirlpool LET6638AN1
Whirlpool LET6638AN2
Whirlpool LET6638AQ2
Whirlpool LET6638AW0
Whirlpool LET6638AW1
Whirlpool LET6638AW2
Whirlpool LET6638DQ0
Whirlpool LET6638DQ1
Whirlpool LET6638DZ0
Whirlpool LET6638DZ1
Whirlpool LET7646AN0
Whirlpool LET7646AQ0
Whirlpool LET7646AQ1
Whirlpool LET7646AQ2
Whirlpool LET7646AW0
Whirlpool LET7646AZ0
Whirlpool LET7646AZ1
Whirlpool LET7646AZ2
Whirlpool LET7646DQ0
Whirlpool LET7646DQ1
Whirlpool LET7646DZ0
Whirlpool LET7646DZ1
Whirlpool LET7646EQ0
Whirlpool LET7646EQ1
Whirlpool LET7646EQ2
Whirlpool LET7646EZ0
Whirlpool LET7646EZ1
Whirlpool LET7646EZ2
Whirlpool LET7848AN0
Whirlpool LET7848AQ0
Whirlpool LET7848AQ1
Whirlpool LET7848AQ2
Whirlpool LET7848AW0
Whirlpool LET7848AZ0
Whirlpool LET7848AZ1
Whirlpool LET7848AZ2
Whirlpool LET7848DQ0
Whirlpool LET7848DQ1
Whirlpool LET7848DZ0
Whirlpool LET7848DZ1
Whirlpool LET8858AN0
Whirlpool LET8858AN1
Whirlpool LET8858AN2
Whirlpool LET8858AQ0
Whirlpool LET8858AQ1
Whirlpool LET8858AQ2
Whirlpool LET8858AW0
Whirlpool LET8858AW1
Whirlpool LET8858AW2
Whirlpool LET8858AZ0
Whirlpool LET8858AZ1
Whirlpool LET8858AZ2
Whirlpool LET8858DQ0
Whirlpool LET8858DQ1
Whirlpool LET8858DZ0
Whirlpool LET8858DZ1
Amana LEU-516 Range - S/c S/i Ddraft Gas
Amana LEU-516D Range - S/c S/i Ddraft Gas
Amana LEU-516E Range - S/c S/i Ddraft Gas
Amana LEU-516G Range - S/c S/i Ddraft Gas
Amana LEU108 Range - S/c S/i Ddraft Gas
Whirlpool LEV4434AN0
Whirlpool LEV4434AW0
Whirlpool LEV4436AN0
Whirlpool LEV4436AW0
Whirlpool LEV4624BG0
Whirlpool LEV4624BN0
Whirlpool LEV4624BW0
Whirlpool LEV4634JQ0
Whirlpool LEV4634JQ1
Whirlpool LEV4634JQ2 29" Electric Dryer
Whirlpool LEV4634JT0
Whirlpool LEV4634JT1
Whirlpool LEV4634PQ0 29" Electric Dryer
Whirlpool LEV4634PQ1 29" Electric Dryer
Whirlpool LEV5634AG0
Whirlpool LEV5634AG1
Whirlpool LEV5634AN0
Whirlpool LEV5634AN1
Whirlpool LEV5634AW0
  #2 (permalink)
Old 09-20-2009, 05:45 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Your Model Number looks to be short a couple digits.
The original problem May have been something that jammed between the drum and the frame.
Run your fingers around the ends of the drum where it meets the frame to see if something is still stuck in there.
Be careful in case it is sharp.
Also check the paddle in the drum to see if it is loose.
If the above is OK you will have to open it up to see what is wrong.
Try to find the general location of the clink (front/back/left/right etc.) so you have an idea where to look
__________________
  #3 (permalink)
Old 09-20-2009, 05:54 AM
Junior Member
Default
I checked around the drum, on the frame and could not find anything causing a stick. The drum moves well right now. How do I check the paddle? The noise comes from the back of the dryer, although I can't say if it top or bottom.
  #4 (permalink)
Old 09-20-2009, 11:15 AM
Junior Member
Default
The correct model number is LER8857EQ1
  #5 (permalink)
Old 09-20-2009, 11:36 AM
Senior Expert
APP Volunteer
Default
Replacement parts for WHIRLPOOL LER8857EQ1 | AppliancePartsPros.com
Just jiggle the paddle to see if it is loose.
Sounds like you will have to open it up
Here is a good site with dryer repair info
http://www.applianceaid.com/dryers.html
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer won't start...buzz sound RockyRocks Dryer Repair 1 06-03-2009 06:27 PM
Dryer Makes Humming Sound ASTRO1954 Dryer Repair 4 03-15-2009 08:45 AM
Slipping Sound While Dryer is On andyslater76 Dryer Repair 7 12-31-2008 02:53 PM
Ice maker makes normal sized ice cubes, but will only dispense crushed ice. TekGod Refrigerator & Freezer Repair 1 12-15-2008 07:25 PM
Dorm sized refridgerator - freezer Dale D Schmitz Refrigerator & Freezer Repair 1 08-14-2008 03:32 PM
