| » Dryer won't shut off on Cotton or Perm Press |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: DJSR473ET0AA Brand: GE Age: 5 - 10 years
My GE dryer won't shut off if I try to dry a load of clothes on Cotton or Permanent Press cycles. The dryer does work on the 'timed dry' cycle. If I try to dry a load on the Cotton or Permanent press cycles, the drum turns, it heats up, but the timer never advances. The cycle will run and eventually dry the clothes, but won't turn off. I have to turn it off manually and the timer remains in the initial position from when I started the cycle.
I have replaced the timer and this did not fix the problem. Strangely enough, I know others who have had the same problem with GE dryers. Any ideas? |
| Display Modes | |
| my oven is shut down | munequita4u2 | Oven Repair (including Ranges and Cooktops) | 7 | 05-29-2008 12:49 PM |
| Automatic Permanent Press Cycle fails to shut off | DECALGUY | Dryer Repair | 3 | 08-04-2007 07:28 PM |
| Element won't shut off | Morris | Oven Repair (including Ranges and Cooktops) | 0 | 08-01-2007 05:55 PM |
