Kenmore elite dryer not calling for heat element to come on-element is not bad. What could this be?
Groups: APP Team
Hi.
Please describe how did you determine that the element is good.
Thank you.
Simon.
i ohmed out the heating element. It is not sending any voltage to the heating element. thank-you
Groups: APP Team
Hi. First of all check if there is 240VAC at the wall outlet. Reset the breaker. If the dryer runs and no heat, check the thermal cut-off, hi-limit for continuity. Check the heat relay (at the control board) contacts No to COM. With dryer turned to heat you should have continuity. The thermal cut-off and hi-limit Part number: 279973
Thank you. Post the results. Simon.
