Discuss
Whirlpool Dryer - Does Not Ignite After ~20 Minutes
 in
Dryer Repair
Problem: Dryer ignites and works well for about 20 minutes or followed by the igniter cycling on and off with
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer - Does Not Ignite After ~20 Minutes
  #1 (permalink)
Old 07-29-2012, 09:56 PM
Junior Member
Quality_Over_Profit is on a distinguished road
Question Whirlpool Dryer - Does Not Ignite After ~20 Minutes
Model Number: LGN2000KQ1   Brand: Whirlpool   Age: 5 - 10 years
Problem: Dryer ignites and works well for about 20 minutes or followed by the igniter cycling on and off with no flame.
Work done: Took dryer and venting completely apart, cleaned, inspected and lubricated where needed. Replaced gas valve coils (part #279834), flame sensor (part #338906) and tried running the dryer with the exhaust duct disconnected, but problem persists.
Question: Read somewhere that the coil resistances should be measured after running the dryer for 15-20 minutes. So below are the resistance measurements for the new coils main, secondary (1/2) and secondary (1/3).
Before running: 1318, 1426, 592
After running ~20 Minutes: 1573, 1666, 677
So the coils would appear to be out of spec slightly before being energized and certainly after being energized for ~20 minutes. But would this cause the problem or is this typical behavior and within an acceptable range due to self-heating?
Although the coils are new, I’m questioning because I also read that a number of people have encountered defective coils (not from any source in particular), new out of the package.
Incidentally, I still have the old coils andthe main coil is open.
Your expert advice is appreciated!
Ads By Google
Related Models
Whirlpool LGN2000KQ1 29"gas Dryer
Whirlpool LGN2000KQ2 29"gas Dryer
Whirlpool LGN2000KT0
Whirlpool LGN2000KT1 29"gas Dryer
Whirlpool LGN2000LG0
Whirlpool LGN2000LG1 29"gas Dryer
Whirlpool LGN2000LW0
Whirlpool LGN2000LW1 29"gas Dryer
Whirlpool LGN2000PG0 29"gas Dryer
Whirlpool LGN2000PG1 29"gas Dryer
Whirlpool LGN2000PW0 29"gas Dryer
Whirlpool LGN2000PW1 29"gas Dryer
Whirlpool LGN3434AW0
Whirlpool LGN3624BN0
Whirlpool LGN3624BN1
Whirlpool LGN3624BN2
Whirlpool LGN3624BW0
Whirlpool LGN3624BW1
Whirlpool LGN3624BW2
Whirlpool LGN3634DW0
Whirlpool LGN3634DW1
Whirlpool LGP6646AN0
Whirlpool LGP6646AN1
Whirlpool LGP6646AN2
Whirlpool LGP6646AW0
Whirlpool LGP6646AW1
Whirlpool LGP6646AW2
Whirlpool LGP6848AN0
Whirlpool LGP6848AN1
Whirlpool LGP6848AW0
Whirlpool LGP6848AW1
Whirlpool LGP7858AN0
Whirlpool LGP7858AN2
Whirlpool LGP7858AQ2
Whirlpool LGP7858AW0
Whirlpool LGP7858AW2
Whirlpool LGP7858AZ2
Frigidaire LGQ1442ES0 Frigidaire/dryer
Frigidaire LGQ2152EE0 Frigidaire/dryer
Frigidaire LGQ2152ES0 Frigidaire/dryer
Frigidaire LGQ332DS0 Frigidaire/dryer
Frigidaire LGQ6000ES0 Frigidaire/dryer
Frigidaire LGQ6000ES1 Frigidaire/dryer
Frigidaire LGQ6000ES2 Frigidaire/dryer
Frigidaire LGQ642DS0 Frigidaire/dryer
Frigidaire LGQ7000EG0 Frigidaire/dryer
Frigidaire LGQ7000ES0 Frigidaire/dryer
Frigidaire LGQ7000ES1 Frigidaire/dryer
Frigidaire LGQ7000ES2 Frigidaire/dryer
Whirlpool LGQ7030KQ0
Whirlpool LGQ7030KQ1
Whirlpool LGQ7030KQ2 29"gas Dryer
Whirlpool LGQ8000HQ0
Whirlpool LGQ8000HQ1
Whirlpool LGQ8000JQ1
Whirlpool LGQ8000JQ2
Whirlpool LGQ8000JQ3
Whirlpool LGQ8000JQ4 29"gas Dryer
Whirlpool LGQ8000JQ5 29"gas Dryer
Whirlpool LGQ8100KQ0
Whirlpool LGQ8100KQ1
Whirlpool LGQ8100KT0
Whirlpool LGQ8100KT1
Whirlpool LGQ8611LG0
Whirlpool LGQ8611LG1 27"gas Dryer
Whirlpool LGQ8611LW0
Whirlpool LGQ8611LW1 27"gas Dryer
Whirlpool LGQ8611PG0 27"gas Dryer
Whirlpool LGQ8611PG1 27"gas Dryer
Whirlpool LGQ8611PG2 27"gas Dryer
Whirlpool LGQ8611PG3 27"gas Dryer
Whirlpool LGQ8611PW0 27"gas Dryer
Whirlpool LGQ8611PW1 27"gas Dryer
Whirlpool LGQ8611PW2 27"gas Dryer
Whirlpool LGQ8611PW3 27"gas Dryer
Whirlpool LGQ8621PG0 27" Gas Dryer
Whirlpool LGQ8621PG1 27" Gas Dryer
Whirlpool LGQ8621PG2 27" Gas Dryer
Whirlpool LGQ8621PG3 27" Gas Dryer
Whirlpool LGQ8621PW0 27" Gas Dryer
Whirlpool LGQ8621PW1 27" Gas Dryer
Whirlpool LGQ8621PW2 27" Gas Dryer
Whirlpool LGQ8621PW3 27" Gas Dryer
Whirlpool LGQ8800JQ0
Whirlpool LGQ8800JQ1
Whirlpool LGQ8800JQ2
Whirlpool LGQ8800JT0
Whirlpool LGQ8800JT1
Whirlpool LGQ8800JT2
Whirlpool LGQ8857HQ0
Whirlpool LGQ8857HQ1
Whirlpool LGQ8857HZ0
Whirlpool LGQ8857HZ1
Whirlpool LGQ8857JQ0
Whirlpool LGQ8857JQ1
Whirlpool LGQ8857JQ2
Whirlpool LGQ8857JQ3
Whirlpool LGQ8857JT0
Whirlpool LGQ8857JT1
Whirlpool LGQ8857JT2
Whirlpool LGQ8857JT3
Whirlpool LGQ8858HQ0
Whirlpool LGQ8858HQ1
Whirlpool LGQ8858HZ0
Whirlpool LGQ8858HZ1
Whirlpool LGQ8858JQ0
Whirlpool LGQ8858JQ2
Whirlpool LGQ8858JQ3
Whirlpool LGQ8858JT0
Whirlpool LGQ8858JT2
Whirlpool LGQ8858JT3
Whirlpool LGQ8858JZ0
Whirlpool LGQ8858JZ2
Whirlpool LGQ9030PQ0 29"gas Dryer
Whirlpool LGQ9030PQ1 29"gas Dryer
Whirlpool LGQ9508KQ0
Whirlpool LGQ9508KQ1
Whirlpool LGQ9508LG0
Whirlpool LGQ9508LW0
Whirlpool LGQ9508LW1 29"gas Dryer
  #2 (permalink)
Old 07-30-2012, 06:05 AM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Try another set of coils.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 07-30-2012, 10:17 AM
Junior Member
Default
Thanksfor the reply. That was my thought, but how do I know another new set of coilswill not have the same issue? The previous new set came in a sealed FSP package(not from APP mind you ). I guess I just have to take a chance, but it's sofrustrating because if you can't rule out the new parts as the problem, it suremakes troubleshooting challenging!
I'll order the part and report back with results.
Thanks again.
  #4 (permalink)
Old 07-30-2012, 10:31 AM
Senior Expert
APP Volunteer
Default
Coils can be hard to troubleshoot to start with.
A lot of times they do not check open like your old one did. They end up failing after they get warmed up and cycle a few times.
From what you have told me if this was something I run into I would go out to my truck, get another set of coils and try it.
Not that easy for you, but if you order them from APP they have a great return policy if they don't do the trick.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Dryer stops after 2 minutes cyclelover63 Dryer Repair 3 07-09-2012 07:01 PM
Whirlpool Gas Dryer only heats for a few minutes dmazza Dryer Repair 1 01-01-2011 11:29 AM
Range and oven will not ignite for 3 minutes Pete3820 Oven Repair (including Ranges and Cooktops) 0 11-30-2010 10:22 PM
maytag dryer ignites,heats for 2 minutes then shuts down & wont re-ignite brhandyman Dryer Repair 0 09-16-2010 01:45 PM
Whirlpool dryer stops after a few minutes ranrog Dryer Repair 2 07-01-2009 08:19 PM
