Discuss
No Heat
 in
Dryer Repair
Dryer runs but no heat. No power to heater coil. Thermal fuse tests good. Ads By Google Related Models Kenmore
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat
  #1 (permalink)
Old 07-29-2012, 11:48 AM
Junior Member
SilkPurse is on a distinguished road
Default No Heat
Model Number: 110.96512200   Brand: Sears   Age: More than 10 years
Ads By Google
Related Models
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
Kenmore 11022042101 WASHER
Kenmore 11022042102 AUTOMATIC
Kenmore 11022052100 WASHER
Kenmore 11022052101 WASHER
Kenmore 11022052102 AUTOMATIC WASHER
Kenmore 11022054100 WASHER
Kenmore 11022054101 WASHER
Kenmore 11022054102 AUTOMATIC WASHER
Kenmore 11022056100 WASHER
Kenmore 11022056101 WASHER
Kenmore 11022056102 AUTOMATIC WASHER
Kenmore 11022062100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022062101 WASHER
Kenmore 11022062102 AUTOMATIC WASHER
Kenmore 11022064100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022064101 WASHER
Kenmore 11022064102 AUTOMATIC WASHER
Kenmore 11022066100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022066101 WASHER
Kenmore 11022066102 AUTOMATIC WASHER
Kenmore 11022082100 WASHER
Kenmore 11022082101 AUTOMATIC WASHER
Kenmore 11022082102 AUTOMATIC
Kenmore 11022084100 WASHER
Kenmore 11022084101 AUTOMATIC WASHER
Kenmore 11022084102 AUTOMATIC
Kenmore 11022086100 WASHER
Kenmore 11022086101 AUTOMATIC WASHER
Kenmore 11022086102 AUTOMATIC
Kenmore 11022292100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022294100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022422100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022432100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022442100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022622100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022632100 WASHER
Kenmore 11022642100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022652100 COMPACT WASHER
Kenmore 11022662100 AUTOMATIC WASHER, COMPACT A/W
  #2 (permalink)
Old 07-29-2012, 11:53 AM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Thermal fuse test good, what about the high limit thermostat?
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
No heat and leads to oven heat element only showing 110volts nobull1466 Oven Repair (including Ranges and Cooktops) 7 06-07-2012 11:23 AM
Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat dsumption Oven Repair (including Ranges and Cooktops) 3 04-04-2011 05:03 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
