I have read threads in the repair forum and thought I had the answer. My Maytag gas dryer fires up the first time and then the flame never comes on again. Igniter glows bright orange and then a click and no flame. So I got new coils and put them in. Now it doesn't even fire the first time. Igniter glows bright orange and then a click and then no flame. The first two coils are staked and I noticed they get hot to the touch. Is it ths gas valve? The two coils have the stem sleeve (thin metal tube) and the small o ring in place. Help!:eek:
What happens if you put the old coils back in? Will it at least fire once like it was with the old coils?
Originally Posted by: ApplianceJunk What happens if you put the old coils back in? Will it at least fire once like it was with the old coils? I put the old coils back in and it will not fire once. What did I break?:)
hi, this is more of a question because i have the same problem, tried two sets of coils, with no gas ignition and the booster and holding coils getting hot. but when i put the old coils back in it fires a couple times before getting nothing again . help!!!!.
