| » dryer wont run after making squeaky noise |
Model Number: leq8000jq2 Brand: Whirlpool Age: 1 - 5 years
I noticed the dryer has been making a high-pitched squeaking noise over the past year or so, it stopped once the dryer started going for a few minutes. Last week, the dryer stopped working altogether. Any ideas why?
The two problems are probably not connected.
First check to see that you have current to the machine. Then disconnect it, take off the back and check continuity in the thermostats/thermal fuse. To fix the squeal, take out the two screws under the lint filter cover. You can then pry up the top and flip it back. You can now take off the front, release the belt and take out the drum. (you can also check the door switch while you are doing this). Replace the rear rolller, idler and belt and that should solve your squeal problem. Good luck.
__________________
| Display Modes | |
| Horrible Loud Squeaky Noise from Dryer | crussell01 | Dryer Repair | 1 | 12-19-2009 06:00 AM |
| Loud Squeaky Dryer Noise | Hart1092 | Dryer Repair | 1 | 11-10-2009 03:28 AM |
| dryer makes loud squeaky noise | ej1954 | Dryer Repair | 0 | 09-01-2008 07:52 AM |
| Loud squeaky noise from dryer | PeggyS | Dryer Repair | 2 | 03-23-2008 10:21 AM |
| Kitchen Aid Dishwasher wont run, making loud buzzing noise. Please help! | jmoriarty@bellsouth.net | Dishwasher Repair | 0 | 02-22-2008 03:53 PM |
