Discuss
Dryer makes rumbling sound when starts
 in
Dryer Repair
When you start the dryer it sounds ok for the first 5 seconds and then it starts to rumble and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer makes rumbling sound when starts
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-12-2007, 06:10 PM
Scottnvegas Scottnvegas is offline
Junior Member
Scottnvegas is on a distinguished road
Exclamation Dryer makes rumbling sound when starts
Model Number: LDG9606AAE   Brand: Maytag   Age: 5 - 10 years
it starts to rumble and then it strarts to make like a popping sound, like
popcorn popping. It also makes that rumbling sound when you stop
the dryer. Another thing I can do but I am not sure
you are suppose to be able to do this is that I can spin the drum from
inside the dryer. When the dryer is off I can reach my hand in and then rotate the drum. Any help would be appreciated. Thanks
Scottnvegas
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-12-2007, 06:51 PM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Does it make a rumble sound for 2-3 seconds after it stops or just when it is running?
Do the cloths seem to dry ok yet?
__________________
  #3 (permalink)
Old 08-12-2007, 07:31 PM
Junior Member
Default
The dryer will start then the rumble starts for a few seconds and then it does the same thing when it stops but doesn't seem to do the rumbling sound while the dryer is drying just at the beginning and end. When it is going it starts making a popping sound when it is drying the clothes. The clothes do get dry after the cycle is over. It is just that the dryer sounds like a train is going to be coming through our door any second. LOL
  #4 (permalink)
Old 08-12-2007, 08:00 PM
Senior Expert
APP Volunteer
Default
I would guess you are hearing the blower wheel.
Blower Wheel
They are plastic and get stripped out in the center were they connect to the motor.
If you remove the front of the dryer you will see the blower wheel.
Try to give the wheel a spin by hand and see if it's lose on the motor shaft.
If it is then replace it.
If the blower wheel is fine I would check the rollers the drum ride on.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven temp guage starts at 315 degrees RBS Oven Repair (including Ranges and Cooktops) 0 08-10-2007 08:28 PM
Freezer fan makes a rattleing sound Ben Tym Refrigerator & Freezer Repair 6 08-10-2007 02:54 PM
Grinding, humming sound underneath while washing MGSHAFFER Dishwasher Repair 1 08-07-2007 12:29 PM
Annoying sound Russ Law Refrigerator & Freezer Repair 1 07-23-2007 10:10 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
