Discuss
heating problem
 in
Dryer Repair
Where to start? Dryer seems to take a very long time to dry clothes if at all. What I have
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » heating problem
  #1 (permalink)
Old 01-27-2008, 05:50 PM
techdowe techdowe is offline
Junior Member
techdowe is on a distinguished road
Default heating problem
Model Number: LER7646eq0   Brand: Whirlpool   Age: 5 - 10 years
Where to start?
What I have done.
1. Cleaned vent duct and made sure that exhaust hose was free of kinks.
2. Run dryer disconnected from exhaust duct (just in case)
3. Measured power at wall socket 220VAC between both lines 120VAC
each line to Ground.
4. Shined flash light down lint trap saw nothing put hand into dryer exhaust
port as far as I could found nothing.
5. Examined heater element through view hole on top appears that all coils
are turning on.
6. Checked continuity SP? across the two heater leads while disconnected
from wiring. checked good.
7. Observed heaters while unit is running. Found the turn on and off. This
is because the cycling thermostat Does that sound right?
8. Found that while heaters are running they draw 22.5 amps per leg.
9. Checked Thermal fuse is good.
10. I checked another switch/Thermostat I think it was high limit. good
continuity.
I hope this description will help you have a good picture of my problem and thanks for all the help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-27-2008, 07:04 PM
RegUS_PatOff RegUS_PatOff is offline
Member
RegUS_PatOff is on a distinguished road
Default
and it used to work better ?
did you check/clean the rest of the exhaust vent (to the outside) ?
try it with the vent disconnected.
is there good air-flow out the vent ?
check the air temp out the back of the dryer (with a meat thermometer) with the dryer empty
(wet clothes will take a long time for the dryer to heat to the limits)
it should be about 150F
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Heating Problem greenhead88 Oven Repair (including Ranges and Cooktops) 0 01-19-2008 01:43 PM
Heating Level Problem Scott8088 Microwave Repair 0 01-18-2008 08:56 AM
Heating Problem Lynn Wachter Oven Repair (including Ranges and Cooktops) 3 12-11-2007 12:32 PM
Gas Dryer Heating Problem RARMSTRONG@ADELPHIA.NET Dryer Repair 1 12-10-2007 01:19 PM
gas dryer heating problem sakks Dryer Repair 1 09-14-2007 06:45 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
