Discuss
electric dryer
 in
Dryer Repair
my older elec whirlpool dryer quit heating, but still blows/runs fine. i cleaned vent out, what could be the problem?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » electric dryer
  #1 (permalink)
Old 07-21-2012, 05:23 PM
Junior Member
jenniferrosecat1 is on a distinguished road
Unhappy electric dryer
Model Number: LEC7858ANO   Brand: Whirlpool   Age: More than 10 years
my older elec whirlpool dryer quit heating, but still blows/runs fine. i cleaned vent out, what could be the problem? good old set and don't want new one.
Ads By Google
Related Models
Whirlpool LEC7858AQ0 ELECTRIC DRYER
Whirlpool LEC7858AQ1 ELECTRIC DRYER
Whirlpool LEC7858AQ2 ELECTRIC DRYER
Whirlpool LEC7858AW0 Residential Dryer
Whirlpool LEC7858AW1 ELECTRIC DRYER
Whirlpool LEC7858AW2 ELECTRIC DRYER
Whirlpool LEC7858AZ0 ELECTRIC DRYER
Whirlpool LEC7858AZ1 ELECTRIC DRYER
Whirlpool LEC7858AZ2 ELECTRIC DRYER
Amana LEC80AW DRYER- ELE
Whirlpool LEC8858DQ0 ELECTRIC DRYER
Whirlpool LEC8858DQ1 ELECTRIC DRYER
Whirlpool LEC8858DZ0 ELECTRIC DRYER
Whirlpool LEC8858DZ1 ELECTRIC DRYER
Whirlpool LEC8858EQ0 ELECTRIC DRYER
Whirlpool LEC8858EQ1 DRYERS
Whirlpool LEC8858EQ2 ELECTRIC DRYER
Whirlpool LEC8858EZ0 ELECTRIC DRYER
Whirlpool LEC8858EZ1 DRYERS
Whirlpool LEC8858EZ2 ELECTRIC DRYER
Whirlpool LEC9000PW0 29" ELECTRIC DRYER
Whirlpool LEC9000PW1 29" ELECTRIC DRYER
Amana LEC90AW DRYER- ELE
Frigidaire LECR23EFE0 Frigidaire/refrigerator
Frigidaire LECR23EFE1 REFRIGERATOR
Frigidaire LECR23EFE2 REFRIGERATOR
Frigidaire LECR23EFE3 REFRIGERATOR
Amana LED20AW DRYER- ELE
Amana LED250 WASHER-TOP LOADING
Amana LED250 DRYER- ELE
Amana LED302 DRYER- ELE
Amana LED302 WASHER-TOP LOADING
Amana LED32AW DRYER- ELE
Amana LED450 WASHER-TOP LOADING
Amana LED450 DRYER- ELE
Amana LED502 DRYER- ELE
Amana LED57AW DRYER- ELE
Amana LED65AW DRYER- ELE
Amana LED850 WASHER-TOP LOADING
Amana LED850 DRYER- ELE
Amana LED902 DRYER- ELE
Amana LED950 WASHER-TOP LOADING
Amana LED950 DRYER- ELE
Frigidaire LEDB400FEE0 Frigidaire/dishwasher
Frigidaire LEDB500FEE0 Frigidaire Elements/dishwasher
Whirlpool LEE9848BQ0 ELECTRIC DRYER
Whirlpool LEE9848BQ1 ELECTRIC DRYER
Whirlpool LEE9848BQ2 ELECTRIC DRYER
Whirlpool LEE9848BZ0 ELECTRIC DRYER
Whirlpool LEE9848BZ1 ELECTRIC DRYER
Whirlpool LEE9848BZ2 ELECTRIC DRYER
Frigidaire LEEB30S9FEA Frigidaire/wall Oven
Frigidaire LEEB30T9FEA Frigidaire/wall Oven
Frigidaire LEEC30S9FEA Frigidaire/cooktop
Frigidaire LEEC36S9FEA Frigidaire/cooktop
Frigidaire LEEFM389FEA Frigidaire/electric Range
Frigidaire LEEFM389FEB Frigidaire/electric Range
Frigidaire LEEFM389FEF ELECTRIC RANGE
Whirlpool LEG8858JZ0 ELECTRIC DRYER
Frigidaire LEGC30S9FEA Frigidaire/gas Cooktop
Frigidaire LEGC36S9FEA Frigidaire/gas Cooktop
Frigidaire LEGFM389FEA Frigidaire/gas Range
Frigidaire LEH1642DS0 Frigidaire/laundry Center
Whirlpool LEL7646EQ0 DRYER
Whirlpool LEL7646EQ1 DRYERS
Whirlpool LEL8858DQ0 ELECTRIC DRYER
Whirlpool LEL8858DZ0 ELECTRIC DRYER
Whirlpool LEL8858EQ0 DRYER
Whirlpool LEL8858EQ1 DRYERS
Whirlpool LEL8858EQ2 ELECTRIC DRYER
General Electric LEM045H01 Electric range
General Electric LEM045H02 Counter top microwave
General Electric LEM045H03 Counter top microwave
General Electric LEM045J01 Counter top microwave
General Electric LEM045J02 Counter top microwave
General Electric LEM045J03 Counter top microwave
General Electric LEM065H01 Electric range
General Electric LEM085H01 Electric range
Amana LEM427L DRYER- ELE
Amana LEM427W DRYER- ELE
Amana LEM437L DRYER- ELE
Amana LEM437W DRYER- ELE
Amana LEM447L DRYER- ELE
Amana LEM447W DRYER- ELE
Amana LEM547L DRYER- ELE
Amana LEM547W DRYER- ELE
Amana LEM847W DRYER- ELE
Whirlpool LEN1000HQ0 ELECTRIC DRYER
Whirlpool LEN1000HQ1 ELECTRIC DRYER
Whirlpool LEN1000PQ0 29"ELECTRIC DRYER
Whirlpool LEN1000PQ1 29"ELECTRIC DRYER
Whirlpool LEN2000JQ0 ELECTRIC DRYER
Whirlpool LEN2000JQ1 ELECTRIC DRYER
Whirlpool LEN2000JQ2 RESIDENTIAL DRYER
Whirlpool LEN2000JT0 ELECTRIC DRYER
Whirlpool LEN2000JT1 ELECTRIC DRYER
Whirlpool LEN2000JT2 RESIDENTIAL DRYER
Whirlpool LEN2000KQ0 DRYER
Whirlpool LEN2000KQ1 29"ELECTRIC DRYER
Whirlpool LEN2000KQ2 29"ELECTRIC DRYER
Whirlpool LEN2000KT0 DRYER
Whirlpool LEN2000KT1 29"ELECTRIC DRYER
Whirlpool LEN2000LG0 RESIDENTIAL DRYER
Whirlpool LEN2000LG1 29"ELECTRIC DRYER
Whirlpool LEN2000LW0 RESIDENTIAL DRYER
Whirlpool LEN2000LW1 29"ELECTRIC DRYER
Whirlpool LEN2000PG0 29"ELECTRIC DRYER
Whirlpool LEN2000PG1 29"ELECTRIC DRYER
Whirlpool LEN2000PW0 29"ELECTRIC DRYER
Whirlpool LEN2000PW1 29"ELECTRIC DRYER
Whirlpool LEN3434AW0 Residential Dryer
Whirlpool LEN3624BN0 ELECTRIC DRYER
Whirlpool LEN3624BN1 ELECTRIC DRYER
Whirlpool LEN3624BN2 ELECTRIC DRYER
Whirlpool LEN3624BW0 ELECTRIC DRYER
Whirlpool LEN3624BW1 ELECTRIC DRYER
Whirlpool LEN3624BW2 ELECTRIC DRYER
  #2 (permalink)
Old 07-22-2012, 05:16 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for Whirlpool LEC7858AN0 ELECTRIC DRYER | AppliancePartsPros.com
Could be a number of things.
First I would start with the power.
Next would be the heating element. Usually 8 to 12 ohms.
Then the thermal cut-off. Should be 0 ohms.
Then the hi-limit or the cycling thermostat. Both should be 0 ohms.
Then the timer contact.
And finally the motor's centrifugal switch. Cannot really check this so if everything else is OK then you assume it is this switch.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE dryer electric overheating but not heating in dryer Helpfulwife Dryer Repair 0 02-25-2012 10:34 AM
General Electric DBLR333ET0WW Electric dryer pmkcreations Dryer Repair 0 05-18-2011 05:12 PM
How do you open up the Maytag Electric Dryer cabinet to get to the dryer drum belt? Darrel Hedman Dryer Repair 1 05-13-2011 06:18 PM
how do I get to the dryer belt on a whirlpool electric dryer? jchase Dryer Repair 1 04-16-2011 02:23 PM
Burned Dryer Plug - Whirlpool Electric Dryer EastCobbSnob Dryer Repair 4 11-17-2009 06:45 PM
