| » Maytag Neptune Dryer |
Model Number: MDE3000AYW Brand: Maytag Age: 5 - 10 years
Dryer was being used this morning then when the wife tried another load it would not start. I have checked continuity on the Thermal fuse and door switch. ALso checked the push to start switch. No problems found. What is next? Thanks for any help you can provide.
Hi.
There are two thermal fuses before the motor (heater fuse). Check them both. Check if the appropriate button pushed all the way at the selector switch. Here are the breakdown diagrams and http://www.appliancepartspros.com/pa...model_id=45255 Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Thanks for quick response. Don't know why but I put it all back together and it is now running? We will see for how long. I have a feeling I'll be back. But before I come back again I will check those two fuses.
If it is running then the fuses are OK.
Once blown they stay blown. If you shut the breaker off when you worked on the unit then that may have been the problem. Sometimes you can loose half the line without actually tripping the breaker. Another possibility is the motor. It has an internal thermal protect. If it overheats the protect opens and you then have to wait for the motor to cool down (protect resets) before it will start again.
__________________
| Display Modes | |
| Maytag Neptune Dryer | crutecaroline | Dryer Repair | 1 | 02-12-2012 02:59 AM |
| maytag neptune dryer won't run | weidy | Dryer Repair | 0 | 03-02-2011 06:24 PM |
| maytag neptune dryer | nancyaherrera | Dryer Repair | 1 | 03-15-2010 12:23 PM |
| maytag Neptune Dryer | eisenberger | Dryer Repair | 7 | 01-04-2010 04:36 PM |
| Maytag Neptune Gas Dryer | ZMARK | Dryer Repair | 0 | 07-19-2008 05:22 AM |
