| » Whirlpool gas dryer won't start. Fuse is good |
Model Number: LGR7648PQ0 Brand: Whirlpool Age: 5 - 10 years
My Whirlpool gas dryer won't start. I have power to the unit. The timer runs, no tumbling, no heat when I press the start button. I can hear the relay click when I press the button after turning the dial to off, then to a setting. Tried all settings. Nothing works. There is continuity across the the thermal fuse.
Any help would be appreciated. Ads By Google Related Models |
I saw a post with a similar problem, but on a Whirlpool electric dryer. That individual finally determined that the issue was the timer motor. How would one go about testing that device?
Hi.
Using the multimeter check the continuity: - door switch Blue to White closed. - start switch Black to Blue closed (with power on and switch pushed in). - timer on timed regular TM-OR, BK-BU, T-W all closed. If all of the above checks OK - replace the motor. Here are the breakdown diagrams and Replacement parts for Whirlpool LGR7648PQ0 29" GAS DRYER | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Disconnected door switch and tested outer leads with door closed, then open: OK - start switch Black to Blue closed (with power on and switch pushed in). Disconnected wires from timer motor and tested Black to Blue: OK - timer on timed regular TM-OR, BK-BU, T-W all closed. With dryer unplugged, set timer to "timed drying" and tested prongs of timer motor. TM-OR: OK BK-BU: OK T-W: NO continuity Does this indicate a different problem? Thanks in advance for all of the assistance |
Hi.
Install the jumper on T-W and start the dryer. If it kicks on - replace the timer. Simon.
__________________
My pleasure.
Simon.
__________________
Quote:
Can you run the dryer with the jumper on T-W, without replacing the timer? Thanks Greg |
Hi.
Why wouldn't the manufacturer make the timer with contacts T-W closed all the time? If the timer is shut, replace it. Simon.
__________________
| Display Modes | |
| Maytag Microwave died, fuse is good | TimTN | Microwave Repair | 1 | 09-03-2010 05:27 AM |
| Whirlpool dryer won't start - all switches, fuse, thermostat OK | grosvenor3 | Dryer Repair | 7 | 12-10-2009 05:49 PM |
| ge Dryer won't start,where will I find the fuse | JOE BLACK | Dryer Repair | 1 | 09-18-2009 07:13 AM |
| Whirlpool Dryer not drying good | hmfary1 | Dryer Repair | 1 | 02-12-2008 07:58 PM |
| Doesn't start - dryer keeps blowing fuse | novas | Dryer Repair | 0 | 11-08-2007 01:57 PM |
