| » Dryer won't heat up and doesn't stop running |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: REX6634RQ0 Brand: Roper Age: 1 - 5 years
Can anyone help with my dryer..It is about a year and a half old and now won't heat and it doesn't stop running.
The first thing I would check is 240V at the power outlet.
If there is nothing wrong with the power then the following parts have to be tested for continuity: 1. The heating element (#17 on the break down diagram) 2. The thermal cut-off (#6 on the break down diagram) 3. The hi limit thermostat (#15 on the break down diagram) 4. The cycling thermostat (#24 on the break down diagram) The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter. - The part number for the heating element is AP3094254 - The part number for the thermal cut-off (including the hi limit thermostat) is AP3094244 - The part number for the hi limit thermostat is AP3131941 - The part number for the cycling thermostat is AP3131939 Good luck. Gene.
__________________
Professional appliance repair services in Orange County, California. Last edited by Gene : 02-12-2008 at 04:38 PM. |
Hi John,
You can find the complete instructions in the one of my previous posts: No Heat on Gas Dryer Here are the break down diagrams for the Roper dryer Model RGX5634KQ2 Gene.
__________________
Professional appliance repair services in Orange County, California. |
| Display Modes | |
| Kenmore dryer/no heat/doesn't stop | Utili23 | Dryer Repair | 1 | 01-25-2008 03:32 PM |
| Gas dryer running but no heat | RBYRD9.1 | Dryer Repair | 5 | 01-22-2008 02:27 PM |
| GE Gas Dryer-no heat, doesn't stop | tenor_ringer | Dryer Repair | 1 | 11-26-2007 02:35 PM |
| dryer wont heat or stop | peter oriol | Dryer Repair | 0 | 11-08-2007 08:34 AM |
| Whirlpool dryer won't stop running | dryrprob | Dryer Repair | 5 | 11-04-2007 02:38 AM |
