| » Kenmore dryer will not heat on second cycle |
Model Number: 110.95872400 Brand: Kenmore Age: 5 - 10 years
Dryer starts and heats on first cycle/round but does not heat on second cycle/round (once flame shuts off). On second cycle ignitor glows but gas never ignites and dryer continues to run without heat. If dryer is left alone for 10 minutes or so, it will ignite on the first cycle and run with heat until it flames out again. Please help!
Hello,
This is an easy fix. You have a bad coil on the safety valve. They are sold as a pair if you look for the part number, it is recommended to replace them as a pair. I'd go into more detail and get the part number for you, but my wife's hollerin', "Time to leave for church!" LOL Good luck and be sure to kill the power before servicing! |
Jerry I spoke too soon. Got about 20 minutes into the cycle and the burner shut off and will not relight. The glow plug lights but the gas valve does not open and the glow plug turns off and I hear a click. It repeats this cycle every few minutes, but the burner never comes back on. Any suggestions?
Hello Jim,
I'm sorry this is the case but sometimes appliances can throw curves. Sounds like the gas valve is the issue. Most of the time the coils solve the problem without incident. If you got those coils from us, since the valve comes with the coils, unless you want to keep them for the next failure, you can call in for a return authorization.Part number: AP5617602 Last edited by Jerry / APP Team : 07-19-2012 at 05:20 AM. |
Jim G42 ... Any solution to the problem? My kenmore He4 gas dryer model 110.95872400 is doing the same thing. When started, it glows and flame ignites, it will get hot and shut off, then glow and flame ignites again. After that, the cylinder glows and I hear a "click" noise, but flame will not ignite again. It will repeat over and over, i.e., glowing, clicking and no flame. Turn the dryer off, wait some time, restart a cycle, it does the same thing. Solution? the diagnostic check reveals nothing, and I've replaced the thermistor and thermal fuse already. Thanks.
| Display Modes | |
| Kenmore Dryer Won't Turn off, timer works, but won't stop. No heat durning the cycle. | bheckenberg | Dryer Repair | 0 | 04-15-2012 04:22 PM |
| Whirlpool Gas Dryer, Auto cycle does not advance and timed cycle does not heat | Costa Rica Kim | Dryer Repair | 0 | 01-25-2012 10:47 AM |
| Kenmore dryer heats on low heat but not on high heat | Mrhollywood334 | Dryer Repair | 0 | 09-11-2010 09:33 PM |
| Gas dryer does not heat or cycle.. | bkopacz | Dryer Repair | 0 | 10-27-2009 08:59 AM |
| Kenmore dryer starts to heat, makes odd cycle noise and stops heating 2 minutes in | pitcher09 | Dryer Repair | 0 | 08-21-2009 04:46 PM |
