| » dryer stuck on code do |
Model Number: cde4205ayj Brand: Crosley Age: 1 - 5 years
installed a new circuit board dryer comes on and now the do code is on and will not go away. How do I check to see where the problem is.
Replacement parts for CROSLEY CDE4205AYJ | AppliancePartsPros.com Here is a service manual and a tech sheet http://www.servicematters.com/maytag...s/16023110.pdf http://www.servicematters.com/maytag...s/16026775.pdf Although I could not find it in the info "do" probably stands for door open. Run the diagnostics to confirm this. Could be a bad switch, a bad connection or the switch is not being closed by the door. Always an outside possibility that the board you received is defective.
__________________
| Display Modes | |
| Dryer squeal like a stuck pig! | Thornapple | Dryer Repair | 7 | 03-23-2012 07:27 AM |
| FL Error Code, Door Latch Stuck Closed | buccolts | Washer Repair | 1 | 10-01-2009 02:53 PM |
| Clothes Stuck In Front Of Dryer | buck032 | Dryer Repair | 1 | 08-26-2008 12:15 PM |
| clothes getting stuck in my dryer | terri | Dryer Repair | 2 | 11-27-2007 12:53 PM |
| my dryer sounds like a stuck pig | Tina | Dryer Repair | 0 | 09-03-2007 08:22 PM |
