Discuss
Flame ignites a couple of times and then quits
 in
Dryer Repair
First off, this forum looks like a great place to get some good advice, so thanks in advance. I have
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Flame ignites a couple of times and then quits
  #1 (permalink)
Old 09-16-2009, 08:56 PM
Junior Member
dowell_p is on a distinguished road
Default Flame ignites a couple of times and then quits
Model Number: LGR8648LW   Brand: Whirlpool   Age: 5 - 10 years
I have a gas dryer that seems to work for 1 or 2 heat cycles and then the heat quits working. When it quits working, you can hear the ignitor switch on and then you hear a low grinding noise.
I have taken it apart and if I let it sit for an hour. I turn it on and it works for 1 cycle. Really good flame. I wait for the next heat cycle, the ignitor glows very hot, but the grinding noise comes back and there is no flame.
I am thinking it is a bad gas valve,any thoughts?
Thanks,
Preston
Ads By Google
Related Models
Whirlpool LGR8648LW0
Whirlpool LGR8648LW1 29"gas Dryer
Whirlpool LGR8648PG0 29"gas Dryer
Whirlpool LGR8648PG1 29" Gas Dryer
Whirlpool LGR8648PQ0 29" Gas Dryer
Whirlpool LGR8648PQ1 29" Gas Dryer
Whirlpool LGR8648PW0 29"gas Dryer
Whirlpool LGR8648PW1 29" Gas Dryer
Whirlpool LGR8857EQ0
Whirlpool LGR8857EQ1
Whirlpool LGR8857EQ2
Whirlpool LGR8857EQ3
Whirlpool LGR8857EZ0
Whirlpool LGR8857EZ1
Whirlpool LGR8857EZ2
Whirlpool LGR8857EZ3
Whirlpool LGR8858DQ0
Whirlpool LGR8858DQ1
Whirlpool LGR8858DZ0
Whirlpool LGR8858DZ1
Whirlpool LGR8858EQ0
Whirlpool LGR8858EQ1
Whirlpool LGR8858EQ2
Whirlpool LGR8858EQ3
Whirlpool LGR8858EZ0
Whirlpool LGR8858EZ1
Whirlpool LGR8858EZ2
Whirlpool LGR8858EZ3
Amana LGS10AW Washer - Top Loading
Amana LGS19AW Dryer - Gas
Amana LGS33AW Dryer - Gas
Amana LGS34AW Washer - Top Loading
Frigidaire LGS389FEA Frigidaire/gas Range
Whirlpool LGT5434AN0
Whirlpool LGT5434AQ0
Whirlpool LGT5434AW0
Whirlpool LGT5436AN0
Whirlpool LGT5436AW0
Whirlpool LGT5624BN0
Whirlpool LGT5624BN1
Whirlpool LGT5624BN2
Whirlpool LGT5624BQ0
Whirlpool LGT5624BQ1
Whirlpool LGT5624BQ2
Whirlpool LGT5624BW0
Whirlpool LGT5624BW1
Whirlpool LGT5624BW2
Whirlpool LGT5624DQ0
Whirlpool LGT5624DQ1
Whirlpool LGT6634AN0
Whirlpool LGT6634AN1
Whirlpool LGT6634AN2
Whirlpool LGT6634AQ0
Whirlpool LGT6634AQ1
Whirlpool LGT6634AQ2
Whirlpool LGT6634AW0
Whirlpool LGT6634AW1
Whirlpool LGT6634AW2
Whirlpool LGT6634DQ0
Whirlpool LGT6634DQ1
Whirlpool LGT6634DZ0
Whirlpool LGT6634DZ1
Whirlpool LGT6638AN0
Whirlpool LGT6638AN1
Whirlpool LGT6638AN2
Whirlpool LGT6638AQ0
Whirlpool LGT6638AQ2
Whirlpool LGT6638AW0
Whirlpool LGT6638AW1
Whirlpool LGT6638AW2
Whirlpool LGT6638DQ0
Whirlpool LGT6638DQ1
Whirlpool LGT6638DZ0
Whirlpool LGT6638DZ1
Whirlpool LGT7646AN0
Whirlpool LGT7646AQ0
Whirlpool LGT7646AQ2
Whirlpool LGT7646AW0
Whirlpool LGT7646AZ0
Whirlpool LGT7646AZ2
Whirlpool LGT7646DQ0
Whirlpool LGT7646DQ1
Whirlpool LGT7646DZ0
Whirlpool LGT7646DZ1
Whirlpool LGT7646EQ0
Whirlpool LGT7646EQ1
Whirlpool LGT7646EQ2
Whirlpool LGT7646EQ3
Whirlpool LGT7646EZ0
Whirlpool LGT7646EZ1
Whirlpool LGT7646EZ2
Whirlpool LGT7646EZ3
Whirlpool LGT7848AN0
Whirlpool LGT7848AQ0
Whirlpool LGT7848AQ1
Whirlpool LGT7848AQ2
Whirlpool LGT7848AW0
Whirlpool LGT7848AZ0
Whirlpool LGT7848AZ1
Whirlpool LGT7848AZ2
Whirlpool LGT7848DQ0
Whirlpool LGT7848DQ1
Whirlpool LGT7848DZ0
Whirlpool LGT7848DZ1
Whirlpool LGT8858AN0
Whirlpool LGT8858AN1
Whirlpool LGT8858AN2
Whirlpool LGT8858AQ0
Whirlpool LGT8858AQ1
Whirlpool LGT8858AQ2
Whirlpool LGT8858AW0
Whirlpool LGT8858AW1
Whirlpool LGT8858AW2
Whirlpool LGT8858AZ0
Whirlpool LGT8858AZ1
Whirlpool LGT8858AZ2
Whirlpool LGT8858DQ0
Whirlpool LGT8858DQ1
Whirlpool LGT8858DZ0
Whirlpool LGT8858DZ1
  #2 (permalink)
Old 09-16-2009, 09:44 PM
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default
The copper in the holding coil retains the most amps of the 2 coils. It gets hot and over time it will fail. Feel it. It gets warm opens and dies. Replace those 2 coils When the gas valve assembly is energized the flame sensor
flame sensor
mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor
Ignitor
and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly. So...
If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these:
Gas operator coils
part# 279834
The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks.
  #3 (permalink)
Old 09-24-2009, 10:03 AM
Junior Member
Default Thank You
Thanks for your help. I replaced the coils and everything works great (much cheaper than replacing the entire valve assembly)
Preston
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
flame goes out after a couple of minutes yahshua Dryer Repair 14 09-24-2009 02:17 PM
gas flame goes out after a couple of minutes yahshua Dryer Repair 2 08-21-2009 08:57 AM
Gas dryer ignites then flame goes out craig8585 Dryer Repair 0 06-28-2009 02:54 PM
Oven re-ignites occassionally, then quits completely radac Oven Repair (including Ranges and Cooktops) 7 02-25-2008 11:18 AM
Dishwasher quits at random times pwisor Dishwasher Repair 0 09-04-2007 10:13 AM
