| » Whirlpool heats for a minute and then no flame |
Model Number: wgd5300sq0 Brand: Whirlpool Age: 1 - 5 years
i opened the dryer, replaced the cycling thermostat and the problem continues. After removing the drum, when i turn it on, it has a flame for about a minute and then turns the flame off for a bit, then it turns on again, and repeats. But when i reassembled it, and tried drying clothes it does not dry. Could someone provide me some tips? The vent is not clogged. Also could someone provide me the ohms readings for all components? Thanks! Ads By Google Related Models |
Hi.
Detach the vent from the dryer, put normal load in and start it. Open little plug in the left bottom corner and observe the flame performance. Gas on for approx. 2 min. then off for 1 min. If the ignitor start glowing but no gas - replace the control coils. If everything works fine, put the vent back and check it again. If the dryer will short cycle- then the problem is the clogged vent. The control coils kit Part number: 279834 You can't check the flame performance with out the dryer being assembled. Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
well, it looks like a coil problem. the igniter lights up but no flame on the second time. I also followed the guide found here :http://appliancejunk.com/blog/2010/0...s-valve-coils/ on checking the coils, and the three terminal solenoid seems to have a bit too much resistance. I will get new solenoids tomorrow and follow up. thanks for the reply!
You are very welcome.
Simon.
__________________
| Display Modes | |
| Gas Dryer Only Heats For One Minute | Ben Brandt | Dryer Repair | 1 | 10-28-2011 03:58 PM |
| Dryer heats for 5 min then flame shuts off, does not re-light | el_timtor | Dryer Repair | 1 | 01-02-2011 01:26 PM |
| dryer runs and heats for a minute then heat shuts off | ddaigle | Dryer Repair | 0 | 07-25-2010 10:23 AM |
| Gas dryer starts, heats for about a minute, shuts off.. | redeyedog | Dryer Repair | 1 | 05-12-2010 02:50 PM |
| amana dryer heats for a minute | josh79 | Dryer Repair | 7 | 09-09-2008 06:44 PM |
