Discuss
Dryer wont run
 in
Dryer Repair
Dryer belt is almost new. The dryer started to make loud scratching sounds and then stopped. When trying to start
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer wont run
  #1 (permalink)
Old 09-16-2009, 03:02 PM
Junior Member
nairobi is on a distinguished road
Cool Dryer wont run
Model Number: LDE6004ACW   Brand: Maytag   Age: 5 - 10 years
Dryer belt is almost new. The dryer started to make loud scratching sounds and then stopped. When trying to start would only make a loud buzzing sound. I replaced the felt front seal. The old one was in horrible condition. I had the belt replaced professionally, but not the felt . The buzzing sound was still present. Spun the drum several times and the dryer then started and ran. However, when stopped , it would not restart, and the buzzing sound came back. Second attempt to spin the drum result in a start, but when stopped, would not restart and NOW no buzzing sound either. Main fuse at fus box was checked. I am back. For the heck of it about an hour later I pressed the start switch and the dryer began running. I decided to let if run. It ran four about 15 min and then stopped. When I attempted to restart, I got the same buzz sound. It acts like something is sticking. The drum wants to spin but it catches and stops.
Ads By Google
Related Models
Maytag LDE6004ACW Dryer - Ele
Maytag LDE606 Dryer - Ele
Maytag LDE608 Dryer - Ele
Maytag LDE610 Dryer - Ele
Maytag LDE612 Dryer - Ele
Maytag LDE612D Dryer - Ele
Whirlpool LDE6400W0
Whirlpool LDE6400W1
Whirlpool LDE6600W0
Whirlpool LDE6600W1
Whirlpool LDE6600W2
Whirlpool LDE6680W0
Whirlpool LDE6680W1
Whirlpool LDE6680W2
Whirlpool LDE6900W0
Maytag LDE6914ACE Dryer - Ele
Maytag LDE6914ACL Dryer - Ele
Maytag LDE6914ACM Dryer - Ele
Maytag LDE710 Dryer - Ele
Maytag LDE712 Dryer - Ele
Maytag LDE713 Dryer - Ele
Maytag LDE7304ACE Dryer - Ele
Maytag LDE7304ACL Dryer - Ele
Maytag LDE7304ACM Dryer - Ele
Maytag LDE7304ADE Dryer - Ele
Maytag LDE7304ADL Dryer - Ele
Maytag LDE7304ADM Dryer - Ele
Maytag LDE7304AEE Dryer - Ele
Maytag LDE7304AGE Dryer - Ele
Maytag LDE7304AGL Dryer - Ele
Maytag LDE7304AGM Dryer - Ele
Maytag LDE7314ACE Dryer - Ele
Maytag LDE7314ACL Dryer - Ele
Maytag LDE7314ACM Dryer - Ele
Maytag LDE7314ADE Dryer - Ele
Maytag LDE7334ACE Dryer - Ele
Maytag LDE7334ACL Dryer - Ele
Maytag LDE7334ACM Dryer - Ele
Maytag LDE7400 Dryer - Ele
Maytag LDE7400ACL Dryer - Ele
Maytag LDE7400ACM Dryer - Ele
Maytag LDE7400ACW Dryer - Ele
Maytag LDE7400ADL Dryer - Ele
Maytag LDE7400ADW Dryer - Ele
Maytag LDE7480ACL Dryer - Ele
Maytag LDE7480ACW Dryer - Ele
Maytag LDE7480ADL Dryer - Ele
Maytag LDE7480ADW Dryer - Ele
Maytag LDE7500 Dryer - Ele
Maytag LDE7500ACE Dryer - Ele
Maytag LDE7500ACL Dryer - Ele
Maytag LDE7500ACM Dryer - Ele
Maytag LDE7500ACW Dryer - Ele
Maytag LDE7500ADE Dryer - Ele
Maytag LDE7500ADL Dryer - Ele
Maytag LDE7500ADM Dryer - Ele
Maytag LDE7500ADW Dryer - Ele
Whirlpool LDE7500W0
Maytag LDE7600 Dryer - Ele
Maytag LDE7600ACG Dryer - Ele
Maytag LDE7600ACL Dryer - Ele
Maytag LDE7600ACW Dryer - Ele
Maytag LDE7600ADL Dryer - Ele
Maytag LDE7600ADW Dryer - Ele
Maytag LDE7600AGG Dryer - Ele
Maytag LDE7600AGL Dryer - Ele
Maytag LDE7600AGW Dryer - Ele
Maytag LDE7800 Dryer - Ele
Maytag LDE7800ACL Dryer - Ele
Maytag LDE7800ACW Dryer - Ele
Maytag LDE7800ADL Dryer - Ele
Maytag LDE7800ADW Dryer - Ele
Whirlpool LDE7800W0
Whirlpool LDE7800W1
Maytag LDE8000 Dryer - Ele
Maytag LDE8000ACL Dryer - Ele
Maytag LDE8000ACW Dryer - Ele
Maytag LDE8000ADL Dryer - Ele
Maytag LDE8000ADW Dryer - Ele
Whirlpool LDE8000W0
Maytag LDE808 Dryer - Ele
Maytag LDE810 Dryer - Ele
Maytag LDE8200 Dryer - Ele
Maytag LDE8200ACE Dryer - Ele
Maytag LDE8200ACL Dryer - Ele
Maytag LDE8200ACW Dryer - Ele
Maytag LDE8200ADE Dryer - Ele
Maytag LDE8200ADL Dryer - Ele
Maytag LDE8200ADW Dryer - Ele
Maytag LDE8300 Dryer - Ele
Maytag LDE8300ACL Dryer - Ele
Maytag LDE8300ACW Dryer - Ele
Maytag LDE8304ACE Dryer - Ele
Maytag LDE8304ACL Dryer - Ele
Maytag LDE8304ACM Dryer - Ele
Maytag LDE8404ACE Dryer - Ele
Maytag LDE8404ACL Dryer - Ele
Maytag LDE8404ACM Dryer - Ele
Maytag LDE8404ADE Dryer - Ele
Maytag LDE8404ADL Dryer - Ele
Maytag LDE8404ADM Dryer - Ele
Maytag LDE8406ACE Dryer - Ele
Maytag LDE8406ACM Dryer - Ele
Maytag LDE8406ADE Dryer - Ele
Maytag LDE8410 Dryer - Ele
Maytag LDE8410ACE Dryer - Ele
Maytag LDE8410ACL Dryer - Ele
Maytag LDE8410ACW Dryer - Ele
Maytag LDE8410ADE Dryer - Ele
Maytag LDE8410ADL Dryer - Ele
Maytag LDE8410ADW Dryer - Ele
Maytag LDE8410W Dryer - Ele
Maytag LDE8414ACE Dryer - Ele
Maytag LDE8414ACL Dryer - Ele
Maytag LDE8414ACM Dryer - Ele
Maytag LDE8414ADE Dryer - Ele
Maytag LDE8416ACE Dryer - Ele
Maytag LDE8416ACM Dryer - Ele
Maytag LDE8416ADE Dryer - Ele
Maytag LDE8420 Dryer - Ele
  #2 (permalink)
Old 09-17-2009, 05:05 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Sounds like you may still have a drum that is putting too much load on the motor. This is causing the motor to overheat, it's internal thermal cutoff trips and you cannot restart is till the thermal cutoff resets.
Try rotating the drum by hand. It should rotate fairly easily. Try this on a couple other dries so you get a feel for what it should feel like.
If drum rotates OK then you probably need a new motor.
__________________
  #3 (permalink)
Old 09-17-2009, 09:20 AM
Junior Member
Default Attempted drum rotation
I did attempt to rotate the drum by hand. It does NOT rotate easliy. While I can get it to rotate it takes an effort to push it around. I have found that if I keep the swithch pushed in and reach up to the start button, I can sometimes get the drum to tumble and begin to work while forcing the drum around but it is not sustainable after a few minutes. Is the motor still the problem?
  #4 (permalink)
Old 09-17-2009, 09:48 AM
Senior Expert
APP Volunteer
Default
Probably but only if the drum is rotating OK so you still have to try rotating on a couple other units.
__________________
  #5 (permalink)
Old 09-18-2009, 09:14 AM
Junior Member
Default Dryer still wont run
Okay. I can start the dryer in its 3 catagories of Regular Dry, Permanent Press and just Plain Air Dry. Basicilly the same thing happens, it runs but then stops. Dryer is hard to turn in any of the settings by hand. Could it be possible that I may have not reinstalled the drum correctly and that is causing the binding? However I will say that when the service tech replaced the belt he stated that the felt tumbler seal should be replaced. I did not do so, and the dryer ran okay, but then after a time the dryer stopped and the motor would make the same buzzing sound ,but not start. So I replaced the felt seal. Any tests on the motor that do not require electrial guages, etc?
  #6 (permalink)
Old 09-19-2009, 02:16 AM
Senior Expert
APP Volunteer
Default
Not really. Only one I know of is spinning the armature to see if the bearings are shot and the following:
http://www.applianceaid.com/may_motor_dryer.html
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer wont Dry needitfixed Dryer Repair 1 10-08-2009 05:21 PM
clothes dryer wont heat timer wont work tampee Dryer Repair 2 01-17-2009 09:53 AM
dryer wont do anything brian emerson Dryer Repair 1 11-16-2008 08:13 PM
Timer wont advance and dryer wont heat awatt26 Dryer Repair 2 06-20-2008 09:43 PM
Dryer wont dry. Sam121974 Dryer Repair 0 01-02-2008 07:49 AM
