Discuss
Electric dryer doesn't dry
 in
Dryer Repair
My dryer is quite old and this past summer took longer than normal to dry. This past weekend it quit
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Electric dryer doesn't dry
  #1 (permalink)
Old 09-16-2009, 11:54 AM
Junior Member
Sandy C is on a distinguished road
Default Electric dryer doesn't dry
Model Number: 1108656811065681   Brand: Sears   Age: More than 10 years
My dryer is quite old and this past summer took longer than normal to dry. This past weekend it quit drying. Live Chat says there are 2/3 thermostats listed and I need to find out from someone which to replace. There's a list of 36 "close matches", but am hoping someone can help me with better than a "close match", please and thank you.
Ads By Google
Related Models
Kenmore 11087070100 AUTOMATIC DRYER
Kenmore 11087070200 AUTOMATIC DRYER
Kenmore 11087070400 AUTOMATIC DRYER
Kenmore 11087070600 AUTOMATIC DRYER
Kenmore 11087070800 AUTOMATIC DRYER
Kenmore 11087273100 GAS DRYER
Kenmore 11087273200 GAS DRYER
Kenmore 11087273400 GAS DRYER
Kenmore 11087273600 GAS DRYER
Kenmore 11087273800 GAS DRYER
Kenmore 11087274100 GAS DRYER
Kenmore 11087274200 GAS DRYER
Kenmore 11087274400 GAS DRYER
Kenmore 11087274600 GAS DRYER
Kenmore 11087274800 GAS DRYER
Kenmore 11087294130 GAS DRYER
Kenmore 11087294140 GAS DRYER
Kenmore 11087294150 GAS DRYER
Kenmore 11087294330 GAS DRYER
Kenmore 11087294340 GAS DRYER
Kenmore 11087294350 GAS DRYER
Kenmore 11087294530 GAS DRYER
Kenmore 11087294540 GAS DRYER
Kenmore 11087294550 GAS DRYER
Kenmore 11087294730 GAS DRYER
Kenmore 11087294740 GAS DRYER
Kenmore 11087294750 GAS DRYER
Kenmore 11087294830 GAS DRYER
Kenmore 11087294840 GAS DRYER
Kenmore 11087294850 GAS DRYER
Kenmore 11087370210 ELECTRIC DRYER
Kenmore 11087379100 GAS DRYER
Kenmore 11087379120 GAS DRYER
Kenmore 11087379130 GAS DRYER
Kenmore 11087379200 GAS DRYER
Kenmore 11087379320 GAS DRYER
Kenmore 11087379330 GAS DRYER
Kenmore 11087379400 GAS DRYER
Kenmore 11087379600 GAS DRYER
Kenmore 11087379620 GAS DRYER
Kenmore 11087379630 GAS DRYER
Kenmore 11087379720 GAS DRYER
Kenmore 11088090100 ELECTRIC DRYER
Kenmore 11088090200 ELECTRIC DRYER
Kenmore 11088090400 ELECTRIC DRYER
Kenmore 11088090600 ELECTRIC DRYER
Kenmore 11088090800 ELECTRIC DRYER
Kenmore 11088182890 ELECTRIC DRYER
Kenmore 11088182891 COMPACT ELECTRIC DRYER
Kenmore 11088184890 ELECTRIC DRYER
Kenmore 11088184891 COMPACT ELECTRIC DRYER
Kenmore 11088390100 ELECTRIC DRYER
Kenmore 11088390110 ELECTRIC DRYER
Kenmore 11088390120 ELECTRIC DRYER
Kenmore 11088390130 ELECTRIC DRYER
Kenmore 11088390200 ELECTRIC DRYER
Kenmore 11088390210 ELECTRIC DRYER
Kenmore 11088390300 ELECTRIC DRYER
Kenmore 11088390310 ELECTRIC DRYER
Kenmore 11088390320 ELECTRIC DRYER
Kenmore 11088390330 ELECTRIC DRYER
Kenmore 11088390400 ELECTRIC DRYER
Kenmore 11088390410 ELECTRIC DRYER
Kenmore 11088390600 ELECTRIC DRYER
Kenmore 11088390610 ELECTRIC DRYER
Kenmore 11088390620 ELECTRIC DRYER
Kenmore 11088390630 ELECTRIC DRYER
Kenmore 11088390700 ELECTRIC DRYER
Kenmore 11088390710 ELECTRIC DRYER
Kenmore 11088390720 ELECTRIC DRYER
Kenmore 11088390730 ELECTRIC DRYER
Kenmore 11088390800 ELECTRIC DRYER
Kenmore 11088390810 ELECTRIC DRYER
Kenmore 11088390820 ELECTRIC DRYER
Kenmore 11088390830 ELECTRIC DRYER
Kenmore 11088416100 ELECTRIC DRYER
Kenmore 11088416110 ELECTRIC DRYER
Kenmore 11088416120 ELECTRIC DRYER
Kenmore 11088416130 ELECTRIC DRYER
Kenmore 11088416200 ELECTRIC DRYER
Kenmore 11088416210 ELECTRIC DRYER
Kenmore 11088416300 ELECTRIC DRYER
Kenmore 11088416310 ELECTRIC DRYER
Kenmore 11088416320 ELECTRIC DRYER
Kenmore 11088416330 ELECTRIC DRYER
Kenmore 11089182990 ELECTRIC DRYER
Kenmore 11089390830 ELECTRIC DRYER
Sears 11089416100 GAS DRYER
Sears 11089416110 GAS DRYER
Kenmore 11089416120 GAS DRYER
Kenmore 11089416130 GAS DRYER
Sears 11089416200 GAS DRYER
Sears 11089416210 GAS DRYER
Sears 11089416300 GAS DRYER
Sears 11089416310 GAS DRYER
Kenmore 11089416320 GAS DRYER
Kenmore 11089416330 GAS DRYER
Sears 11089416400 GAS DRYER
Sears 11089416410 GAS DRYER
Sears 11089416600 GAS DRYER
Sears 11089416610 GAS DRYER
Kenmore 11089416620 GAS DRYER
Kenmore 11089416630 GAS DRYER
Sears 11089416700 GAS DRYER
Sears 11089416710 GAS DRYER
Kenmore 11089416720 GAS DRYER
Kenmore 11089416730 GAS DRYER
Sears 11089416800 GAS DRYER
Sears 11089416810 GAS DRYER
Kenmore 11089416820 GAS DRYER
Kenmore 11089416830 GAS DRYER
Kenmore 11089417100 GAS DRYER
Kenmore 11089417300 GAS DRYER
Kenmore 11089417600 GAS DRYER
Kenmore 11089417700 GAS DRYER
Kenmore 11089417800 GAS DRYER
Kenmore 11089419100 GAS DRYER
Kenmore 11089419110 GAS DRYER
Kenmore 11089419111 GAS DRYER
Kenmore 11089419120 GAS DRYER
  #2 (permalink)
Old 09-17-2009, 05:36 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Here's what you need to do.
Get a multi-meter if you do not already have one (or even better find a friend who has one and will use it for you)
Check to make sure you have 120v to each side of the connection block.
Then unplug the machine and take off the back. You will see the thermostats/thermal fuses. Test each one for continuity. The one that is open is your problem.
While you have the back off clean out the lint chute and the venting both internal and the vent tube to the outside. It is likely obstructed and caused your slow drying and the fuse/themostat to fail.
Your model number is not correct, there should be 8 digits after the 110.
Good luck
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burned Dryer Plug - Whirlpool Electric Dryer EastCobbSnob Dryer Repair 4 11-17-2009 06:45 PM
ELECTRIC Dryer Max Harlan Dryer Repair 6 04-26-2009 05:51 AM
Electric dryer will not run GA60 Dryer Repair 0 02-08-2009 06:10 AM
Electric dryer gets too hot cojo1957 Dryer Repair 2 10-28-2008 04:50 AM
Gas dryer to electric dryer convertion. Fhabeeow Dryer Repair 1 01-08-2008 07:49 PM
