Discuss
dryer wont run at all
 in
Dryer Repair
Im working on my neighbors dryer and I have checked the door switch and the thermal fuse and still nothing.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer wont run at all
  #1 (permalink)
Old 09-16-2009, 08:04 AM
Junior Member
neighbor is on a distinguished road
Default dryer wont run at all
Model Number: leq9858   Brand: Whirlpool   Age: 5 - 10 years
Im working on my neighbors dryer and I have checked the door switch and the thermal fuse and still nothing. I do have 220v to the terminal block. please help? thanks
Ads By Google
Related Models
Whirlpool LEQ9858LG0
Whirlpool LEQ9858LG1 29"electric Dryer
Whirlpool LEQ9858LW0
Whirlpool LEQ9858LW1 29"electric Dryer
Whirlpool LEQ9858PG0 29"electric Dryer
Whirlpool LEQ9858PG1 29"electric Dryer
Whirlpool LEQ9858PW0 29"electric Dryer
Whirlpool LEQ9858PW1 29"electric Dryer
Whirlpool LEQ9957KQ0
Whirlpool LEQ9957KT0
Admiral LER1115AAW Range - F/s Std Ele
Whirlpool LER2614BW0
Whirlpool LER2614BW1
Whirlpool LER2614BW2
Whirlpool LER2614DW0
Whirlpool LER2614DW1
Whirlpool LER2614EW0
Whirlpool LER2614EW1
Whirlpool LER2614EW2
Whirlpool LER2614JQ0
Whirlpool LER2614JQ1
Whirlpool LER2614JQ2 29"electric Dryer
Frigidaire LER331DS0 Frigidaire/dryer
Admiral LER3330AAB Range - S/c F/s Ele
Admiral LER3330AAW Range - S/c F/s Ele
Admiral LER3330AAZ Range - S/c F/s Ele
Whirlpool LER3422AN0
Whirlpool LER3422AW0
Whirlpool LER3424AW0
Whirlpool LER3622BN0
Whirlpool LER3622BW0
Whirlpool LER3622DQ1
Whirlpool LER3622DQ2
Whirlpool LER3622DZ1
Whirlpool LER3622DZ2
Whirlpool LER3622HQ0
Whirlpool LER3622HQ1
Whirlpool LER3622PQ0 Compact Electric Dryer
Whirlpool LER3622PQ1 Compact Electric Dryer
Whirlpool LER3622PQ2 Compact Electric Dryer
Whirlpool LER3624BN2
Whirlpool LER3624BN3
Whirlpool LER3624BW0
Whirlpool LER3624BW1
Whirlpool LER3624BW2
Whirlpool LER3624BW3
Whirlpool LER3624DQ0
Whirlpool LER3624DQ1
Whirlpool LER3624DQ2
Whirlpool LER3624DZ0
Whirlpool LER3624DZ2
Whirlpool LER3624EQ0
Whirlpool LER3624EQ1
Whirlpool LER3624JQ0
Whirlpool LER3624JQ1
Whirlpool LER3624JQ2 29" Electric Dryer
Whirlpool LER3624PQ0 29" Electric Dryer
Whirlpool LER3624PQ1 29" Electric Dryer
Whirlpool LER3634EW0
Whirlpool LER3634EW1
Whirlpool LER3634EW2
Whirlpool LER3634JW0
Whirlpool LER3634JW1
Admiral LER3725AAC Range - S/c F/s Ele
Whirlpool LER4434AN0
Whirlpool LER4434AN1
Whirlpool LER4434AQ0
Whirlpool LER4434AQ1
Whirlpool LER4434AW0
Whirlpool LER4434AW1
Whirlpool LER4436AN0
Whirlpool LER4436AW0
Whirlpool LER4600PQ0 29" Electric Dryer
Whirlpool LER4600PQ1 29" Electric Dryer
Whirlpool LER4624BN0
Whirlpool LER4624BN1
Whirlpool LER4624BN2
Whirlpool LER4624BQ0
Whirlpool LER4624BQ1
Whirlpool LER4624BQ2
Whirlpool LER4624BW0
Whirlpool LER4624BW1
Whirlpool LER4624BW2
Whirlpool LER4624DQ0
Whirlpool LER4624DQ1
Whirlpool LER4624DZ0
Whirlpool LER4624DZ1
Whirlpool LER4634BQ0
Whirlpool LER4634BQ1
Whirlpool LER4634BQ2
Whirlpool LER4634DQ0
Whirlpool LER4634DQ1
Whirlpool LER4634DZ0
Whirlpool LER4634DZ1
Whirlpool LER4634EQ0
Whirlpool LER4634EQ1
Whirlpool LER4634EQ2
Whirlpool LER4634EW0
Whirlpool LER4634EZ0
Whirlpool LER4634EZ1
Whirlpool LER4634EZ2
Whirlpool LER4634JQ0
Whirlpool LER4634JQ1
Whirlpool LER4634JQ2 29" Electric Dryer
Whirlpool LER4634JT0
Whirlpool LER4634JT1
Whirlpool LER4634JT2 29" Electric Dryer
Whirlpool LER4634JZ0
Whirlpool LER4634PQ0 29" Electric Dryer
Whirlpool LER4634PQ1 29" Electric Dryer
Whirlpool LER4634PT0 29" Electric Dryer
Whirlpool LER4634PT1 29" Electric Dryer
Whirlpool LER5434AN0
Whirlpool LER5434AW0
Whirlpool LER5600HQ0
Whirlpool LER5600HZ0
Whirlpool LER5600JQ0
Whirlpool LER5600JT0
Whirlpool LER5620KQ0
Whirlpool LER5620KQ1
  #2 (permalink)
Old 09-16-2009, 08:33 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Here is the wiring diagram
http://www.servicematters.com/docs/w...%203406661.pdf
Did you also check that you had 120 volts L1 to Neutral? This is required to run the motor and the timer. Sometimes you can loose the Neutral without tripping the breaker.
__________________
  #3 (permalink)
Old 09-16-2009, 11:39 AM
Junior Member
Default
yes, I did check that also, Ive had some experience working on dryers and this one has me stumped. thanks for your reply.
  #4 (permalink)
Old 09-17-2009, 04:43 AM
Senior Expert
APP Volunteer
Default
I noticed you have two threads going so I will use the other one after this post as running two will just confuse things.
I assume that the thermal fuse you checked was the one on the blower as this is the one for the motor.
I would put the unit into timed dry as this circuit path is the easiest.
If the timer advances then you know that it is getting 120 volts so the door switch is closing. If not the door switch comes to the top of the list as the problem part.
Then unplug the unit and check the components in this circuit path for resistance.
At the top of the list would be the start relay contacts and the door switch.
Then the timer contacts.
Remember to remove the wire from one side of the component before measuring it. This prevents reading an alternate/parallel circuit path.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer wont Dry needitfixed Dryer Repair 1 10-08-2009 05:21 PM
clothes dryer wont heat timer wont work tampee Dryer Repair 2 01-17-2009 09:53 AM
dryer wont do anything brian emerson Dryer Repair 1 11-16-2008 08:13 PM
Timer wont advance and dryer wont heat awatt26 Dryer Repair 2 06-20-2008 09:43 PM
Dryer wont dry. Sam121974 Dryer Repair 0 01-02-2008 07:49 AM
