| » will not stay started |
Model Number: 110.60972990 Brand: Kenmore Age: 5 - 10 years
When I push the "START" button the dryer will; start but stops when I let off the push button.
I have the machine apart and I have a meter to measure continuity and I have a diagram that I found inside the contro0l panel. I also have the machine apart (top and front is off as well as tub. Ihave vacuumed and cleaned the inside and I am ready to replace any bad parts and start to re-assemble. My problem is I cannot find the bad part. I started with the "push to start switch" p/n 3395382. I Dis-connected it and it appears to be a "momentary contact switch" (can you confirm?). It shows open until I push it and shows continuity as long as I hold it down and then opens again when I release it. I assume it is good. Next ther are 3 electrical parts on the metal tube surronding the heater element itself: a "thermal cut off switch", p/n 3977394, ,I reemoved the connections and I get continuity. a high limit thermostat", p/n 3390291. I removed connections and I get continuity a "heater element it self, p/n 3392661. I removed the connections and get continuity. I also removed the coil and inspected and cleaned it and found no apparent defects. Then on the blower tube there is "thermal fuse" p/n 3390719. I disconned and I get continuity thru it. Also on the blower tube is a "thermister" I disconnected leads and I get an ohm reading of 9.46 and then 9.99K. I don't mind ordering the part(s) i need but I am reluctant to repalce good ones un less they are going bad. What should I check next? I would feel a whole lot better if I could indentify a bad part and replace it. I just don't know what to try next. Incidently altho the dryer is 10 or more years old it is like new. My wife and I are elderly and use iy very little. Thanks and I will look forward to your suggestions Doug Casey Ads By Google Related Models |
Hi.
Most likely you have a bad motor start winding. You need to replace the motor Part number: 279787 Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
Check for 120VAC to the motor contacts 4 and 5 with the start switch pushed in. If there is voltage - replace the motor. Thank you. Simon.
__________________
| Display Modes | |
| frigidaire washer wont stay started for 2sec. | tkell65 | Washer Repair | 1 | 07-14-2011 10:05 PM |
| Dryer Won't Stay Started | gbroberts | Dryer Repair | 1 | 03-31-2011 04:18 AM |
| dryer will not stay started | lakeview | Dryer Repair | 0 | 06-02-2009 06:05 AM |
| Dryer wont fire up or stay started. | BrianE | Dryer Repair | 0 | 05-26-2009 02:48 PM |
| dryer won't stay started | 8man | Dryer Repair | 2 | 03-28-2009 05:16 AM |
