Discuss
maytag touchpad
 in
Dryer Repair
i have a maytag mde5500 dryer, i went out of town for the night and when i got back dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » maytag touchpad
  #1 (permalink)
Old 07-08-2012, 02:39 PM
Junior Member
hendrj26 is on a distinguished road
Exclamation maytag touchpad
Model Number: mde5500ayw   Brand: Maytag   Age: 5 - 10 years
i have a maytag mde5500 dryer, i went out of town for the night and when i got back dryer was beeping and the led touchpad is non responsive. before i left the dryer worked fine had to de wrinkle some shirts and everything was working as it should. I checked the door switch, the hi limit therm as suggested in another post, and they tested good, as well as testing for resist and cont on the touch pad j7 connnector and the analog meter did not move while pressing or not pressing start switch. there a few lights on on the touchpad but none of them are responsive when pushed and the time remaining display is good just displaying 42 as it would if it were to start with the settings that are selected. also cannot get it to go into service mode to do the membrane test. and one last thing if i press the signal + and - buttons at same time i am able to use the other buttons on pad(heat +-, time+-, damp dry more dry, etc.) but unit will not start. Just wanting to be a little more confident the problem is the touch pad and not control board, the control board looks fine no burns or black areas.
thanks,
jonathan
Ads By Google
Related Models
Maytag MDE5500AYW Dryer - Ele
Maytag MDE5500AZQ Dryer - Ele
Maytag MDE5500AZW Dryer - Ele
Maytag MDE5806AYK Dryer - Ele
Maytag MDE5806AYW Dryer - Ele
Maytag MDE5806AZK Dryer - Ele
Maytag MDE5806AZW Dryer - Ele
Maytag MDE5960AYW Dryer - Ele
Maytag MDE6000AUW Dryer - Ele
Maytag MDE6000AYQ Dryer - Ele
Maytag MDE6000AYW Dryer - Ele
Maytag MDE6000AZQ Dryer - Ele
Maytag MDE6000AZW Dryer - Ele
Maytag MDE6200AYQ Dryer - Ele
Maytag MDE6200AYW Dryer - Ele
Maytag MDE6200AZQ Dryer - Ele
Maytag MDE6200AZW Dryer - Ele
Maytag MDE6400AGW Dryer - Ele
Maytag MDE6400AYQ Dryer - Ele
Maytag MDE6400AYW Dryer - Ele
Maytag MDE6400AZW Dryer - Ele
Maytag MDE6460AYW Dryer - Ele
Maytag MDE6460AZW Dryer - Ele
Maytag MDE6657BYQ Dryer - Ele
Maytag MDE6657BYW Dryer - Ele
Maytag MDE6700AYW Dryer - Ele
Maytag MDE6700AZW Dryer - Ele
Maytag MDE6800AYB Dryer - Ele
Maytag MDE6800AYQ Dryer - Ele
Maytag MDE6800AYW Dryer - Ele
Maytag MDE6800AZQ Dryer - Ele
Maytag MDE6800AZW Dryer - Ele
Maytag MDE7057AYQ Dryer - Ele
Maytag MDE7057AYW Dryer - Ele
Maytag MDE7057AZW Dryer - Ele
Maytag MDE7400AYQ Dryer - Ele
Maytag MDE7400AYW Dryer - Ele
Maytag MDE7400AZQ Dryer - Ele
Maytag MDE7400AZW Dryer - Ele
Maytag MDE7460AYQ Dryer - Ele
Maytag MDE7460AYW Dryer - Ele
Maytag MDE7500AYQ Dryer - Ele
Maytag MDE7500AYW Dryer - Ele
Maytag MDE7500AZQ Dryer - Ele
Maytag MDE7500AZW Dryer - Ele
Maytag MDE7550AGW Dryer - Ele
International MDE7550AGW Dryer - Ele
Maytag MDE7600AUW Dryer - Ele
Maytag MDE7600AYQ Dryer - Ele
Maytag MDE7600AYW Dryer - Ele
Maytag MDE7600AZQ Dryer - Ele
Maytag MDE7600AZW Dryer - Ele
Maytag MDE7657AYQ Dryer - Ele
Maytag MDE7657AYW Dryer - Ele
Maytag MDE7657BYQ Dryer - Ele
Maytag MDE7657BYW Dryer - Ele
Maytag MDE7658AYQ Dryer - Ele
Maytag MDE7658AYW Dryer - Ele
Maytag MDE7658BYQ Dryer - Ele
Maytag MDE7658BYW Dryer - Ele
Maytag MDE7757AYQ Dryer - Ele
Maytag MDE7757AYW Dryer - Ele
Maytag MDE7758AYQ Dryer - Ele
Maytag MDE7758AYW Dryer - Ele
Maytag MDE8000AYQ Dryer - Ele
Maytag MDE8000AYW Dryer - Ele
Maytag MDE8000AZW Dryer - Ele
Maytag MDE8057AYQ Dryer - Ele
Maytag MDE8057AYW Dryer - Ele
Maytag MDE8057AZW Dryer - Ele
Maytag MDE8058AYQ Dryer - Ele
Maytag MDE8058AYW Dryer - Ele
Maytag MDE8400AYQ Dryer - Ele
Maytag MDE8400AYW Dryer - Ele
Maytag MDE8400AZW Dryer - Ele
Maytag MDE8416AYA Dryer - Ele
Maytag MDE8416AYW Dryer - Ele
International MDE8426AAW Dryer - Ele
International MDE8426AGW Dryer - Ele
Maytag MDE8500AYW Dryer - Ele
Maytag MDE8506AYA Dryer - Ele
Maytag MDE8506AYW Dryer - Ele
Maytag MDE8506AZW Dryer - Ele
International MDE8550AGW Dryer - Ele
International MDE8550BGW Dryer - Ele
Maytag MDE8600AYQ Dryer - Ele
Maytag MDE8600AYW Dryer - Ele
Maytag MDE8600AZQ Dryer - Ele
Maytag MDE8600AZW Dryer - Ele
Maytag MDE8757AYQ Dryer - Ele
Maytag MDE8757AYW Dryer - Ele
Maytag MDE9206AYA Dryer - Ele
Maytag MDE9206AYW Dryer - Ele
Maytag MDE9206AZW Dryer - Ele
Maytag MDE9306AUW Dryer - Ele
Maytag MDE9306AYA Dryer - Ele
Maytag MDE9306AYW Dryer - Ele
Maytag MDE9306AZA Dryer - Ele
Maytag MDE9306AZW Dryer - Ele
Maytag MDE9316AYA Dryer - Ele
Maytag MDE9316AYQ Dryer - Ele
Maytag MDE9316AYW Dryer - Ele
Maytag MDE9316AZW Dryer - Ele
Maytag MDE9357AYA Dryer - Ele
Maytag MDE9357AYQ Dryer - Ele
Maytag MDE9357AYW Dryer - Ele
Maytag MDE9360AYW Dryer - Ele
Maytag MDE9390AYW Dryer - Ele
Maytag MDE9390AZW Dryer - Ele
Maytag MDE9420AYW Dryer - Ele
Maytag MDE9420AZW Dryer - Ele
Maytag MDE9520AYQ Dryer - Ele
Maytag MDE9520AYW Dryer - Ele
Maytag MDE9520AZW Dryer - Ele
Maytag MDE9557AYA Dryer - Ele
Maytag MDE9557AYQ Dryer - Ele
Maytag MDE9557AYW Dryer - Ele
Maytag MDE9557AZA Dryer - Ele
Maytag MDE9557AZQ Dryer - Ele
Maytag MDE9557AZW Dryer - Ele
  #2 (permalink)
Old 07-11-2012, 02:49 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
As long as you did the above correctly then the keypad is toast.
If other keys responded like they should have then you can be fairly confident that you did the test correctly.
The usual way to troubleshoot is the way you did it. Check the keypad and if it checks out OK replace the control board. This is still a bit of a crap shoot but your odds are better.
In your case the keypad fails so I would replace that.
Since you have done the troubleshooting you may want to order from AppliancePartsPros as they will let you return the keypad if it does not solve your problem. See their return policy.
Please do not order both control board and keypad and then just return the one that does not fix it. If many people did this then the company would probably have to change the return policy to the same as most other part supply houses (you buy it you own it and no returns).
__________________
  #3 (permalink)
Old 07-21-2012, 01:06 PM
Junior Member
Angry maytag mde5500
thank you for your input. the dryer actually started working again, but has now stopped. same issue as before. i would assume that the keypad is on its way out. any suggestions.
  #4 (permalink)
Old 07-21-2012, 01:09 PM
Junior Member
Angry touchpad acting up again
thankyou for the inout the dryer started working again, but now has stopped again. same issue as before. is this a sign that the tuch pad is on its way out?
  #5 (permalink)
Old 07-22-2012, 03:47 AM
Senior Expert
APP Volunteer
Default
Cannot say if it points to the keypad or the control board.
Either part can go intermittent.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Dishwasher touchpad problem roncar9 Dishwasher Repair 7 09-04-2011 06:49 PM
touchpad Rpatolia Microwave Repair 0 08-10-2011 01:35 PM
Maytag Microwave touchpad problems bones1515 Microwave Repair 0 04-07-2010 05:19 PM
Touchpad accord Oven Repair (including Ranges and Cooktops) 3 08-12-2008 06:42 PM
Maytag Dishwasher - no lights to touchpad philfrommaine Dishwasher Repair 1 01-04-2008 05:11 PM
