| » Dryer will not heat |
Model Number: DLG7188WM Brand: -other- Age: 1 - 5 years
Hello, my LG DLG7188WM Gas Dryer shows "cooling" on display when first turned on. Gas burner will come on for a few seconds, (I can hear it fire up) but clothes do not warm or dry. I have run diagnostic test - get a "nE". I checked the thermistor - it showed 9.6 Kohms at 76 deg F. The thermostat below the thermistor tested @ 0.3 ohms. The manual reset thermostat tested @ 0 ohms, the thermostat on back side of burn chamber tested at 0 ohms. What is next? Please help, buried in clothes!
Well, I see 111 people have looked and no suggestions. It is not the control board. Replaced it and still getting a "cooling" display on panel even before dryer has heated. The gas burner will start, but will shut off when dryer heats a little and not come back on. Any suggestions from the Pro's. What would you do if you were in the field and this happened? Thanks.
Thanks to tech on parts Q&A. It was the gas valve and probably weak igniter. It ohmed out perfectly and would light initially, but would not stay lit. I was told to try a new one and I HAVE A DRYER AGAIN!!!
Thank you for the input. Congrats on the successful repair.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| gas dryer only heats on perm press and low heat, but not on high heat? | GrandCanyonEngineer | Dryer Repair | 0 | 03-02-2011 02:23 PM |
| Kenmore dryer heats on low heat but not on high heat | Mrhollywood334 | Dryer Repair | 0 | 09-11-2010 09:33 PM |
| Dryer stops after a few minutes with heat on - will run continuously with heat off | somegeek | Dryer Repair | 0 | 05-27-2010 01:35 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
