Discuss
Estate Dryer Heats Up But Motor Stopped
 in
Dryer Repair
My wife was using the dryer, opened the door to check the clothes, shut the door and when she pushed
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Estate Dryer Heats Up But Motor Stopped
  #1 (permalink)
Old 07-05-2012, 08:22 AM
Junior Member
krSRinPA is on a distinguished road
Default Estate Dryer Heats Up But Motor Stopped
Model Number: EED4300TQ0   Brand: Estate   Age: 1 - 5 years
My wife was using the dryer, opened the door to check the clothes, shut the door and when she pushed the start button again the drum would not turn. The elements heat up and the timer is still running but no rotation of the drum. The drum turns freely and the belt is in tact. No noise from the motor. Also if you open the door the heating elements stay on which I thought the door switch would not allow. Is it possible several failures at the same time? Thanks for any suggestions.
Ads By Google
Related Models
Whirlpool EED4300TQ0 29" Electric Dryer
Whirlpool EED4400SQ0 29"electric Dryer
Whirlpool EED4400TQ0 29" Electric Dryer
General Electric EED4500D0WW Electric dryer
General Electric EED6500D0WW Electric dryer
General Electric EED6500D1WW Electric dryer
Whirlpool EEH061CW0
Whirlpool EEH061FW0
Whirlpool EEH061FW1
Whirlpool EEH091CW0
Whirlpool EEH091FW0
Whirlpool EEH091FW1
Whirlpool EEH151CW0
Whirlpool EEH151CW5
Whirlpool EEH151FW1
Whirlpool EEH152FW0
Whirlpool EEH153FW0
Whirlpool EEH153FW5
Whirlpool EEH153FW8
Whirlpool EEH181FW0
Whirlpool EEH182FW0
Whirlpool EEH182FW5
Whirlpool EEH182FW7
Whirlpool EEH231FW1
Whirlpool EEH232FW0
Whirlpool EEH232FW5
Whirlpool EEH232FW8
Whirlpool EEH271FW1
Whirlpool EEH272FW0
Whirlpool EEH272FW1
Whirlpool EEH272FW5
Whirlpool EEH272FW6
Whirlpool EEH272FW8
Whirlpool EEL131CTWL0
Whirlpool EEL131CTWR0
Whirlpool EEL131CTWR1
Whirlpool EEL131CTWR2
Whirlpool EEL131CTWR3
Whirlpool EEL131CTWR4
Whirlpool EEL141CTWR0
Whirlpool EEL141CTWR1
Whirlpool EEL141ETWR0
Whirlpool EEL142CTWR0
Whirlpool EEL142ETWR0
General Electric EER2000C00BB Electric range
General Electric EER2000C00CC Electric range
General Electric EER2000C00WW Electric range
General Electric EER2000C04BB Electric range
General Electric EER2000C04CC Electric range
General Electric EER2000C04WW Electric range
General Electric EER3000D00BB Electric range
General Electric EER3000D00CC Electric range
General Electric EER3000D00TW Electric range
General Electric EER3000D01BB Electric range
General Electric EER3000D01CC Electric range
General Electric EER3000D01TW Electric range
General Electric EER3000F01BB Electric range
General Electric EER3000F01CC Electric range
General Electric EER3000F01TW Electric range
General Electric EER3000H01BB Electric range
General Electric EER3000H01KC Electric range
General Electric EER3000H01TW Electric range
General Electric EER3000H02BB Electric range
General Electric EER3000H02KC Electric range
General Electric EER3000H02TW Electric range
General Electric EER3000K01BB Electric range
General Electric EER3000K01KC Electric range
General Electric EER3000K01TW Electric range
General Electric EER3000K02BB Electric range
General Electric EER3000K02KC Electric range
General Electric EER3000K02TW Electric range
General Electric EER3000L01BB Electric range
General Electric EER3000L01KC Electric range
General Electric EER3000L01TW Electric range
General Electric EER3000L02BB Electric range
General Electric EER3000L02KC Electric range
General Electric EER3000L02TW Electric range
General Electric EER3001D00SS Electric range
General Electric EER3001D01SS Electric range
General Electric EER3001F01SS Electric range
General Electric EER3001H00SS Electric range
General Electric EER3001H01SS Electric range
General Electric EER3001H02SS Electric range
General Electric EER3001K01SS Electric range
General Electric EER3001K02SS Electric range
General Electric EER3001L01SS Electric range
General Electric EER3001L02SS Electric range
General Electric EER3002D00CC Electric range
General Electric EER3002D01CC Electric range
General Electric EER3002F01CC Electric range
General Electric EER3002H00CC Electric range
General Electric EER3002H01CC Electric range
Whirlpool EERT14PWR0
Whirlpool EEST14PWR0
Whirlpool EEST14PWR1
Whirlpool EEST17PWR0
Whirlpool EET121DTWR0
Whirlpool EET121ETWR0
Whirlpool EET122DTWR0
Whirlpool EET131DTWR0
Whirlpool EET131DTWR1
Whirlpool EET131DTWR2
Whirlpool EET131JTWR0
Whirlpool EET131JTWR1
Whirlpool EET132DTWR0
Whirlpool EET132JTWR0
Whirlpool EET133DTWR0
Whirlpool EET133JTWR0
Whirlpool EET134DTWR0
Whirlpool EET134JTWR0
Whirlpool EET141DTWR0
Whirlpool EET141DTWR1
Whirlpool EET141EKWR0
Whirlpool EET141EKWR1
Whirlpool EET141EKWR2
Whirlpool EET141JKWL0
Whirlpool EET141JKWR0
Whirlpool EET141JKWR1
Whirlpool EET141PKWR0
Whirlpool EET142EKWR0
  #2 (permalink)
Old 07-07-2012, 05:18 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for Estate EED4300TQ0 29" ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run and the thermostats cannot regulate it.
Sounds like it may have blown the thermal fuse.
There seems to be a problem with the parts breakdown and the wiring diagram.
There is usually a thermal fuse on the blower assembly but the parts does not show one. This is the fuse that is in-line with the motor in the wiring diagram.
Check to see if the unit has one. White rectangular device with 2 wires going to it. It should be 0 ohms.
It is a little strange that a grounded element would blow that thermal fuse as it normally blows the thermal cut-off (Item 6 in Section 1). Basically this is also a thermal fuse just looks different.
Also a good time to check/clean your vent system.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Estate Dryer Stopped Heating kimyoung Dryer Repair 1 05-17-2011 04:45 AM
Estate dryer - motor runs, no heat JohnDoeV Dryer Repair 1 02-06-2011 05:45 AM
Estate dryer motor hums but won't run jcsun Dryer Repair 1 01-02-2011 01:24 PM
Estate gas dryer heats for 2min then gas shuts off wyomingoutlaw Dryer Repair 1 09-25-2010 12:49 PM
Dryer heats without motor running deyoung5 Dryer Repair 0 04-24-2010 06:56 PM
